  1. ukmayhem
    ukmayhem Member
    55
    How difficult is it to change one on a 1995 1.8t?
  2. billybravo
    billybravo Active Member
    1,045
    your gonna need a vice to knock off the cv joint
  3. Daveiow
    Daveiow Member
    264
    unless u buy on of those ones that u dont need to take the shaft of to replace!! Although id do it proply if uyr going to do it!!
  4. Charlies604
    Charlies604 Member
    203
    U can do it on the car... u need to remove the lower arms, put the hub bolt in a screw it in, the hub will fall off, take the boot off, pop on the new one push the CV joint back on the splines as its an all in one unit, nothin to fall out and get lost. then bolt it all back up!
    Its eaaasy, tho i found out the hard way! All u need is a boot,, grease and some time
    Ciao
