CV boot torn - replace boot or joint
TeKnodriver Jan 18, 2014
  1. TeKnodriver
    TeKnodriver Biodiesel Purrrr
    166
    N/S CV boot torn, needs changing for MOT.
    there is a slight clicking when turning right under acceleration.
    Is it worth just sticking on a new boot and grease, or, given driveshaft need to come out of hub anyway,
    just put a new joint on there.
    Also, Haynes says entirely remove driveshaft for this job -
    is that really necessary?
  2. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group S-line owners group
    3,697
    642
    Biggest issue is just having enough movement on the upright to get the drive shaft out, removing the 6 bolts hold the shaft to the gearbox is the simple part and it's far easier to work on the shaft when its removed from the car. If the pinch bolt has not been removed in the last few years then I would not try and remove it find another way in getting more movement on the upright.
  3. TeKnodriver
    166
    thanks for info,
    do you mean even to change the boot it would be easier to try and get the whole shaft out? as it where...
  4. Sulli79
    Sulli79 Active Member
    541
    37
    If you've got a clicking your best off taking the cv out to clean it all up properly inspect it then if it's good regrease and fit the complete unit,
  5. If the CV has quite a few miles on it, and it's clicking it's worth trying the J& R joints on eBay. I have two on my 2.5tdi B5 they have been fine, no noises and £16 each inc delivery, can't go wrong.
    I accidentally ordered a 1.9tdi joint (on night shift and wasn't paying attention) so it's sitting in it's box in my garage.
    I'm in Perth if anyone wants it
  6. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    defo easier to pull whole unit
    pinch bolt removal and juducious use of steering wheel and it will come out
  7. Bradderz_1988
    3,945
    235
    As above definately easier to remove the full shaft oh and the n/s shaft will fall out by just undoing the hub bolt and flange bolts its the drivers thats the tricky one due to the exhaust and lack of space !!!
    Also make sure you have the correct clamping pliers for the clips otherwise they will just pop off !!
  8. TeKnodriver
    166
  9. spartacus 68
    spartacus 68 Active Member quattro Audi A2 Audi Avant Owner Group
    366
    54
    Yes, they'll do the trick. I used to buy GKN driveline boots (comes with clips, grease and new hub bolt) but would now recommend genuine Audi boot instead. GKN were lasting a couple of years before showing wear.
    No need to remove pinch bolt - but by all means do it if yours comes out okay. Remember and grease the new pinch bolt before reinstalling.
  10. TeKnodriver
    166
    finally got a moment this afternoon to put driveshaft back in.
    just a quick check on torque settings:
    the hub bolt on the end of the outer CV -
    mine is just under 14mm diameter along the thread, I take it this is the M14 bolt.
    spec I have is 115 Nm (+180 deg)
    this sound right??
    haynes mentions two settings, 190 Nm (+180deg) for the M16 bolt
