CV boot leaking
noelg100 May 14, 2009
  1. noelg100
    noelg100 New Member
    19
    Hi All,
    My MOT just advised that my O/S/F inner cv boot was leaking grease. They said it could be a bit of a pig to fix so was wondering what the likely cost was? I guess it is mainly just labour.
    I'll call my local Audi garage to get an idea of cost but this isn't something I'd be looking for Audi to do :)
    The car is a 2001 S3.
    Cheers,
    Adam
  2. themanthatcan
    themanthatcan Member VCDS Map User
    661
    Hi Adam,
    I've just checked my paperwork and I was charged £97.50 to have both the inner and outer NSF CV gaitors changed. That was £57.50 of labour (an hour) and £40 worth of parts.
    HTH,
    Andy
  3. Fuzzy felt
    Fuzzy felt Member
    101
    Hi,
    i got mine done today by a VAG Independent, £150 for both outers.
  4. fingermouse
    fingermouse thats me
    4,003
    112
    the part is about £20 from audi you get boot, grease, clips and new bolt. No more than a ! hr job to do. You do need the right tool to tighten up the clamp.
  5. noelg100
    noelg100 New Member
    19
    Thanks for the updates :)
    So it doesn't look like too big a job with about an hours labour and inexpensive parts.
    Is it worth having the inner and outer done? I assume there is an inner and outer on the other side? I guess as the MOT said that only the inner was leaking I should only really look at fixing this. Is there any benefit of replacing the others or is it just a case of fixing what looks to be broken and leave the rest.
    The help is really appreciated.
  6. fingermouse
    4,003
    112
    ah just reread its the inner , I did the outer one on mine but had to do the cv joint eventually. Think it had got contaminated as it split bad :(
