Cv boot gone can't get pinch bolt out
Ian2012 May 4, 2013
  1. Ian2012
    Ian2012 Active Member
    473
    29
    Oh joy of joys it's cv boot time, the drivers side has gone and despite which huffing and puffing i can't shift the pinch bolt up top it's seized big time.
    So how else can i get the shaft out of the hub, or remove the damn bolt, i haven't tried heat as i only have a basis plumbing type blow torch and i don't want to fry the upper joints either.
    ta
    ian
  2. AlexGSi2000
    AlexGSi2000 Well-Known Member VCDS Map User
    1,464
    199
    If you remove the two lower ball joints on the suspension arms then it will give you enough maneuverability to get the shaft out.
    pauldazzle likes this.
  3. spartacus 68
    spartacus 68 Active Member quattro Audi A2 Audi Avant Owner Group
    382
    60
    Hang fire with lower ball joints. You can disconnect at inner driveshaft. Held in place with splined bolts. You'll need to remove plastic trim where driveshaft goes from wheel to engine, and bell housing guard on inner driveshaft. Turn wheel to hard lock and you should be able to remove.
  4. Ian2012
    473
    29
    i cant seem to access one of the guard bolts and then bloody downpipe is in the way it's a 1.9 diesel thats the culprit
  5. You don't need to separate anything to remove the shaft, I have recently replaced my driveshaft, unbolt from the gearbox and undo shaft bolt, and its a bit fiddly but it will feed through past the suspension parts
