cutting bumpstops?
205man Oct 7, 2010
  1. 205man
    205man Active Member
    1,071
    13
    when i fitt my new springs the weekend do i have to or is it worth me cutting ht the bump stops on the shocks before refitting? just dont fancy idea putting all back together to find they bottom out on the stops all the time
    cheers alan
  2. nwmlarge
    nwmlarge flat out
    219
    why not leave them on whole then see how it goes and if they bug you cut the top half off while still on the car.
    it's pretty easy
  3. aragorn
    18,020
    716
    how low are you going?
  4. 205man
    1,071
    13
    well ive already got the standard sport suspension fitted, and they list my new ones at about 35/40mm drop on a standard car.. and less on ones fitted with sports
    so im guessing will be about 20/25mm lower than i already have
    also i know how to remove the rear shocks they ive done those before and very simple, but ive not done the front and have seen couple different methods suggested, has anyone got the easiest route? or link to it
    thanks alan
  5. nwmlarge
    nwmlarge flat out
    219
    undo arb
    undo top mounts through the rubber grommit holes.
    undo lower mount
    take strut out.
    done.
