Custom making map sensor pipe
s3gazz Jun 3, 2013
  1. s3gazz
    s3gazz Well-Known Member
    1,383
    105
    Was wondering guys if it would make any difference making a map sensor pipe. For some reason I've just only noticed I've got 63mm pipe from turbo to end of charge pipe then drops to 53mm back into 63mm to 76mm inter cooler and out to 63mm again up to map sensor pipe which is 53 mm and 53mm throttle body pipe and 63mm throttle body.
    Does this not mean the map sensor pipe is restricting everything as the pipe aren't hard to change but the map sensor pipe is. What u guys think
  2. beachbuggy
    beachbuggy Well-Known Member
    1,931
    201
    Buy a map flange/adaptor from forge and get it welded to a piece of alloy pipe.
  3. s3gazz
    1,383
    105
    Was thinking somate like that dan with a 63mm aluminium pipe modded to reach the throttle body some how
  4. Andrew@A.L.D
    3,879
    617
    I'm still running the standard one and that was fine at 500 bhp
  5. s3gazz
    1,383
    105
    I just think it would flow better with a bigger pipe rather than a smaller one Ie restriction or less volume of air passing through
  6. cecilthesausage
    cecilthesausage ...It's Never Finished...
    933
    112
    This is what you want fella... I'm getting pipework fabricated from my cooler to my 75mm Throttle Body..... With this incorporated...[​IMG]
  7. Andrew@A.L.D
    3,879
    617
    I would say don't waste your money until your on a 500+ level
    I still plan to run the standard one even when or if i hit 600 bhp
  8. <tuffty/>
    21,363
    3,931
    The gains from up-sizing the pipework will vary but the basics are the tighter the hole the more boost required to obtain a target airflow... going 63mm all round will improve overall flow but only if the rest of the charge system has no restrictions too...
    You will benefit from 63mm from 300hp up... there are various theories about pipework sizing and most people that are on 500hp or more use 70mm pipework but tbh for a road car 63mm is more than enough...
    The OE MAP tube is an odd shape and a little constricted in places... while its not the end of the world if you leave it in place should you decide to change it I would suggest you plan the pipework out accordingly as I have seen some real bodge jobs in the past and it defeats the object.... I relocated my battery to get a decent path... either of the charge pipe sections I made would improve flow potential but just replacing the MAP tube is probably not worth the effort unless redoing that whole section...
    Andrew, seriously dude... at your levels you would really benefit from normalising the pipework... airspeeds alone generate heat and the volume of air and boost levels you will be running thats a lot of friction... larger pipework will drop overall airspeed and reduce heat generated by friction... will also require less boost to achieve power... worth considering in your case dude...
    superkarl likes this.
  9. badger5
    9,507
    2,003
    just because you can force an amount of air thru a smaller than ideal hole does'nt make it an efficient way of forcing it.
    size it uniformly and of correct size. /End Of
    <tuffty/> likes this.
  10. StaceyS3
    StaceyS3 Well-Known Member
    2,505
    502
    Pressume you want something like this gazz ;)
    Pretty sure forge sell them
  11. cecilthesausage
    933
    112
    The picture in my last post is from the Forge website Stacey....
  12. s3gazz
    1,383
    105
    The hole pipe is 27 from forge so what I was going to do is get that it's 270 mm long and 63mm ID then fabricate my own bit of pipe on onto the end and make something to reach the throttle body as well. I do want a good consistent flow all the way around so this is my opposition I think.
    like we say its all about the flow same sized pipe not matter what has got to be better than it dropping to 53mm anywhere in the pipe line
  13. s3gazz
    1,383
    105
    ye Stacey was going for that but for an extra £10 the whole pipe from forge is 27
  14. cecilthesausage
    933
    112
    This is what Tufty fabricated....[​IMG]
    Mine will be similar to this as my battery has been relocated to boot....I just need 63 to 75 silicone for my Throttle Body...
  15. <tuffty/>
    21,363
    3,931
    ....and more recently...
  16. cecilthesausage
    933
    112
    Nice....
  17. superkarl
    superkarl MAN OF STEEL
    9,495
    2,436
    forge motorsport?! and a two figure price tag?! 27? as in, 2 and a 7? thats it?
    slowcoach3 likes this.
  18. cecilthesausage
    933
    112
    There £33 with the Vodka And Tonic.....
  19. Andrew@A.L.D
    3,879
    617
    Chill guys
    I have one made up for mine but just not fitted it as i hate taking the bumper off and was going to change it when i get a new bumper as mine has a bit of damage to it
  20. badger5
    9,507
    2,003
    who needs to chill? eh?
  21. StaceyS3
    2,505
    502
    Double figure price tag......mine cost me a bit of free time at work ; )
  22. superkarl
    9,495
    2,436
    would that happen to equate to say, the cost of a crate of your prefered lager?
  23. s3gazz
    1,383
    105
    Looks nice does that pipe. Ill be buying the forge one and adding some extra pipe so we will see why happens in a few week along with a large port inlet and Wmi
  24. cecilthesausage
    933
    112
    Me to I have this one and 75mm Throttle Body....[​IMG]
  25. s3gazz
    1,383
    105
    I don't fancy paying all that money for a inlet mani lol so ill make my own with some AEB runners and my s3 standered inlet
  26. cecilthesausage
    933
    112
    Lol..... I'm in that deep now mate a bit more doesn't really make a difference anymore.....
  27. s3gazz
    1,383
    105
    Lol pal might as well ha
