ctsad003 BUT STILL NO REAR SPEAKER/ SUB SOUND
95ram3 Apr 4, 2014
  1. 95ram3
    95ram3 Member
    Hi I tried to fit in my new aftermarket radio using this wire but I still have no speaker/subwoofer sound from the back. I have a 2005 a3 8p 5door 1.6FSI with half amplified rear speakers.
    I believe it is not bose as it does not say it on the doors.
    How is the cable meant to be wired into the stereo. Any diagrams or how to's?
    Any help would be appreciated
    After market stereo: Alpine CDA-137BTi
  2. hollow
    hollow Well-Known Member
    1,404
    162
    if you car has the amp and sub as standard then there is no rear speaker outputs from the factory unit , it will however have low level outputs from the original unit ,these will need modifying slightly so the can be connected to the new head units pre outs.
    what stereo did you previously have ?
  3. 95ram3
    95ram3 Member
    audi concert II
    what do you mean?
  4. Sidhu88
    Sidhu88 Active Member
    808
    76
    Run the blue wire off the adaptor to ignition 12v. The amp doesn't turn on from normal amp-remote feeds off a head unit, they dont give enough power out for the factory amp to turn on. Once u've done this, fade the sound to the rear until the speakers sound level
  5. andyam
    andyam Active Member
    485
    With your cable. Change the fader to about a 1/4 to the back...and should hear music. It's plug and play really.
  6. 95ram3
    95ram3 Member
    Thanks I got that to work. How do i get the radio to save settings ? is that possible?
