crystal display
pagey Jul 5, 2009
  1. pagey
    pagey Member
    41
    hi all i have a 99 audi a4 avant the crystal display dosent fully work properly is there an easy fix for this or is it expensive ,have noticed that when the interior is cold the display works better
    thanks mike
  2. Nilz
    11,361
    899
    There is a sticky in the 8l A/S3 forum, that should help you out mate.
  3. pagey
    pagey Member
    41
    thanks for that mate very interesting
  4. twostrokepower
    twostrokepower Member
    131
    dont mess about with it i to had lcd screen that had some pixels not working so sent mine away to so "called dash repair specialist" (tosser)on ebay to get returned back to me saying couldnt fix it then placed back in car and car would not start as dash is coded to ecu had to join AA to get car taken to audi (60miles)and got a new dash fitted costing £450.
    my advice is live with it or buy new from audi ! i also tryed a second hand unit from a audi-sport member (£120) but no audi dealer would code for me .
  5. au_sjo
    au_sjo Member
    102
    That sounds as if the repair person sent back a different unit? Simply removing the LCD module shouldn't affect the immobilisor. Did you mark you original unit so you knew it was yours?
  6. twostrokepower
    131
  7. rasA4
    rasA4 Four Rings Mafia Specialist Team V6 Audi A4 saloon
    3,287
    119
    Very common problem, how bad is it?
  8. Broken Byzan
    13,237
    465
    If its AEB engined a used dash can be read and recoded using vagcom and Vagtacho. I have the stuff here to do it, but may not be local to you. However the vag tacho cable can be had form ebay for around £40 and that will enable you to read the SKC code from the replacement dash to then allow you to recode it to the car. Sounds difficult, but it really inst
  9. olds_kool
    olds_kool Active Member VCDS Map User
    1,094
    15
    keep an eye on ebay, i bought brand new cluster for my tdi and repaired s4 clocks for my 1.8t fairly cheap and as mark said you can get vag tacho and vagcom and code keys, cluster and correct mileage
    certainly cheaper than new one from a dealer
  10. Siena
    Siena Active Member
    2,626
    I get them repaired, no issues so far.
    Inc. postage, £200. The screen is replaced, and it carries a 48 month warranty too.
  11. twostrokepower
    131
    i did try vag com which could not code and rang siena for advice to which he did say he could get coded to car but suffolk is a long way from cornwall at the time last year so it did seam the cheaper and quicker option for me to buy new from audi , still have second hand clocks for sale !
  12. rasA4
    3,287
    119
    As Byzan said you will need or get someone who has Vagtacho and vag.com to sort this out to reprogram it inc mileage
  13. pagey
    pagey Member
    41
    thanks guys for your replys not long had the car and i love it ,thought their might have been a quick fix but if i need to spend a couple of hundred to get it done i need to get a couple of other jobs done first ,i got to get a air con compressor changed first (zexel if anyones got a good one ).
    then i have the dreaded turbo rattle ineed to fix also .
    thanks chaps
  14. pagey
    pagey Member
    41
    hi
    wouldnt mind meeting up with some of you lot would like to show somone what i have bought just to see what you think i live in wolverhampton thanks mike
  15. ginna104
    ginna104 Member
    32
    i bought a 2nd hand dash for 100 quid as my display was same as yours, i got it recoded for 25.00 from audi and it kept the mileage what was on the 2nd hand clocks not the mileage what was on my clocks ! so lower mileage lol
  16. Nilz
    11,361
    899
    Pagey there is a regular meet in Cov, if you are interested, its on every Wednesday and there is a massive one on tonight, have a look in the midland meet section, all the info is there.
    few of the lads from here are going there tonite.
