Cruise not working after battery replaced
juddster Jul 15, 2012
  1. juddster
    juddster New Member
    29
    Hi,
    I have recently had to replace my battery and noticed now my cruise control is not functioning.
    Can anyone tell me if i need to reset my cruise control after fitting a new battery, will it have thrown up a fault code which needs clearing?
  2. jb0o
    jb0o North East Forum Moderator Regional Rep Site Sponsor VCDS Map User
    2,664
    118
    Thats a first...
    Urm, some systems need a voltage of at least 12v to function though the vehicle being started and running fine should be sufficient.
    Could be a coincidence and your clutch switch has went.
    Get it on VCDS to check for codes / test the clutch switch.
  3. RMH1A4cab
    RMH1A4cab I'm in Cruise control
    551
    19
    It may need recoding with vcds.
  4. juddster
    juddster New Member
    29
    Thanks, I guess it could be a coincidence.
  5. fooby
    fooby Member
    43
    Try disconnecting the battery again, and reconnecting.
    Mine sometimes stops working if the battery has been disconnected, at the same time my mfsw stops working. just reconnecting seems to fix it.
