Cruise control?
rob v6 Feb 1, 2010
  1. olds_kool
    olds_kool Active Member VCDS Map User
    1,094
    15
    is it cable throttle on a four cylinder?
  2. aragorn
    18,601
    870
    Afaik the stalks are all interchangable across the range. Theres a part number different for pre and post facelift iirc, but that doesnt mean they arent compatible.
  3. Geeman
    Geeman Low Life
    1,318
    Awesome...! Will go get it then!
  4. Geeman
    Geeman Low Life
    1,318
    Anyone else know if it's compatible...? Going to go back to the scrap yard and get it at lunchtime if so...
  5. aragorn
    18,601
    870
    Ok i looked up the PN's for you.
    4D0953513M is the facelift number, and it also suits 1998 and 1999 pre-facelift A4's, and 1994-1999 A8 range.
    4D0953513C is the earlier number fitting 1995 to 1997 A4's, however it also is listed as fitting the A8, over the same date range as the other one.
    A quick google shows up this:
    http://cgi.ebay.de/Audi-A8-D2-Tempo...ItemQQimsxZ20100206?IMSfp=TL100206165004r6704
    Which is the same as this:
    http://cgi.ebay.de/ws/eBayISAPI.dll?ViewItem&item=230399322736
    (the second pic is missing the clamp, but that comes off anyway)
  6. Geeman
    Geeman Low Life
    1,318
    Brill!
    So what you're saying is, that this CC stalk from a pre-facelift car will be fine for my facelift A4...?
    Awesome!
  7. Geeman
    Geeman Low Life
    1,318
    Kufatek harness has just arrived.
    I've now got two problems... 1) no colour coding (how the hell are you supposed to know which connector goes where... the wires are bound together in tape, making it nearly impossible to trace them from the connector to their ends!) and 2) there are 6 wires coming out the connector, but I've only got 5 loose ends at the other end of the wiring...
    Hmmm...
  8. aragorn
    18,601
    870
    multimeter and a wiring diagram?
  9. Geeman
    Geeman Low Life
    1,318
    Yeah, will do that... then label up the end wires.
    After visiting the scrap yard this lunchtime... here's what I've got...
    1) The harness:
    2) the stalk(it's a bit grubby... must have been sat outside for ages!)
    I imagine that one of the wires in the harness is looped into one of the others. The multi-meter will show which one is which, so no worries there.
    The other problem I have is that the guide posted here on how to fit the CC to a Passat uses completely different coloured wiring to the wires coming out the back of the CC stalk from the A4 donor.
    Aaaaaargh! lol
  10. aragorn
    18,601
    870
    the plug itself is numbered, use those instead of colors.
    I totally screwed up the wiring on mine, because i used the A8 loom with the A4 diagram and went solely on the colors.
  11. Geeman
    Geeman Low Life
    1,318
    Numbered... of course it is!
    I'm sure the guide on here is for non-DBW cars though...
    I have no problem with everything about fitting this, apart from the wiring (which I guess is the most important part!)
    Where can I get an instruction guide/wiring diagram for this?
  12. aragorn
    18,601
    870
    you got etka?
  13. Geeman
    Geeman Low Life
    1,318
    You mean VAG CAT...? Or is ETKA something completely different?
  14. Geeman
    Geeman Low Life
    1,318
  15. aragorn
    18,601
    870
    Thats not a B5 diagram mate.
    ETKA is the vag workshop manuals CD.
    I'll dig the cruise diagram out for you in a bit.
  16. Geeman
    Geeman Low Life
    1,318
    Oh, ******. Pretty glad though as I still didn't understand it!
    That would be very helpful if you could do that for me... beers when I see you!
  17. Geeman
    Geeman Low Life
    1,318
    Any luck on the ETKA cruise control wiring diagram...?
    Incidentally, where can I get hold of a copy of the ETKA myself...? Is it more comprehensive than the VAG CAT I use...?
    http://www.vagcat.com/
  18. aragorn
    18,601
    870
    geh i'm quoting the wrong names
    Vagcat is an online version of ETKA
    What i meant to say was ELSAWin, which is the workshop manual.
    I'll dig the diagrams out for you this morning, i forgot last night :(
  19. Geeman
    Geeman Low Life
    1,318
    No worries... lol
    Anything will be appreciated! I'm a doofuss when it comes to wiring...
    EDIT: I've just ordered myself a copy from the 'Bay of Plenty... but would still appreciate it if you could dig me out a diagram too. :icon_thumright:
  20. aragorn
    18,601
    870
    The only pin not showing is {58} which connects to +12v, you can pick this up at the clutch switch or the brake pedal switch, its a black/blue wire.
    If you dont have a clutch switch at the moment, you need to add one, i can show you the diagram for that if required.
  21. Geeman
    Geeman Low Life
    1,318
    Do I need a clutch switch with a DBW set-up?
  22. aragorn
    18,601
    870
    It might already be there, but yes, the ecu needs to know you've depressed the clutch when cruise is active, or it'll ram the revs round to the limiter...
  23. Geeman
    Geeman Low Life
    1,318
    Ooooh, okay. I'm assuming that's what the little 'box 58' is on the diagram then...?
    And I'm also assuming that the harness wire without the 'spade' on the end goes to that.
  24. Geeman
    Geeman Low Life
    1,318
    Apologies for being annoying, but bear with me.
    From that diagram, I've got this in my head...
    CC pin No.1 goes to pin No.7 on white ECU connector
    CC pin No.2 goes to pin No. 8 on white ECU connector
    CC pin No.3 goes to pin No. 9 on white ECU connector
    CC pin No.4 is looped to CC pin No. 6
    CC pin No.5 goes to clutch switch
    CC pin No.6 goes to pin No.10 on white ECU connector
    Now... that makes some sense to me now. It was the whole wire colouring (or non-colouring) that was throwing me. If I keep to pin numbers, I think I'll be okay.
    THANKS VERY MUCH!
    Hang on... you mention [58] being a 12v +ve connection from either the clutch or brake pedal. Does it want to connect to both switches so that it turns off the CC in both circumstances...?
  25. aragorn
    18,601
    870
    pin 5 is just 12v power in.
    Brake and clutch switches also have a 12v feed to them (with their other side connected back to the ECU), so its just a useful place to take it from.
    If you needed to add a clutch switch, it would have 12v to one side of it, and the other side connected to the ecu.
    Also, your saying you'll connect these to the "white ECU connector". The white "T15" connector is actually in the plenum, behind the ecu, not on the ECU itself. If there is a connection between that white plug, and the ECU harness, then you can simply attach them there as you describe. If there isnt a connection there, you need to take it directly to the ECU multiplug itself on the appropriate pin numbers.
    I've never done this personally, so i dont know whats present and what isnt.
  26. Geeman
    Geeman Low Life
    1,318
    Better for me to get everything physically in place and then get an auto electrician in to wire it in...?
    I'm sure they'll appreciate that all the 'hard work' is already done and there's a nice wiring diagram...
  27. aragorn
    18,601
    870
    lol dont be a wuss. If the white connector has wires in the other side of it, then just plug it in and off you go.
  28. olds_kool
    1,094
    15
    its four wires into the white connector (getting to white connector and working out how to open it is the hard part)
    and one wire to the small red wire in another block
    that guide is the one i used (it is for dbw) and once you strip everything down it should be clearer
  29. Geeman
    Geeman Low Life
    1,318
    So you don't think there's any need for a clutch switch being added then?
    Will start it next week (I'm off work, so no need to use the car) and see how I get on...
  30. olds_kool
    1,094
    15
    if its dbw ecu already has those inputs and it controls cruise so all your doing is wiring in a switch
    unlike cable where your wiring in a control unit
    was doner car cable throttle by the way? would love to fit it to my tqs
  31. Geeman
    Geeman Low Life
    1,318
    The donor stalk I have at the moment was from a cable throttle A4.
    Still has 6-pin output though... so I figured it'll be okay.
    I'm still waiting on another stalk from an A8, but it's not arrived yet.
  32. aragorn
    18,601
    870
    I dont like the idea of connecting the flying lead to a red wire. That means its live all the time...
    Pick up the correct switched live (Black/Blue) at the clutch/brake switches as the diagram shows.
    I've never heard of the clutch switch having to be added to DBW cars before, but the diagram does say the clutch switch is only fitted to cars with cruise, so who knows.
    Thanks for confirming its all done at the white block, i wasnt sure.
