Cruise Control
Nic May 19, 2009
  1. Nic
    Nic Member
    44
    A couple of days ago my cruise control stopped working. Has anyone else had this problem and do you know if it's a big job to sort out?
  2. kevandalice
    kevandalice Member
    69
    Possibly the switch on either the clutch or brake pedal
  3. <tuffty/>
    21,879
    4,202
    The main parts aren't expensive, as mentioned above.... the clutch and brake switch play a big part. If your brake lights come on and off ok, I would look at the clutch switch but tbh I would VAGCOM it firt to see if there are any fault codes.
    Mine would occasionally switch off for no apparent reason, hitting resume would kick it back in and VAGCOM picked up a fault with the brake switch which I have now changed.
