cruise control
tangerinedream Sep 14, 2011
  1. tangerinedream
    tangerinedream Member
    249
    hi all i want to have cruise control but dont want to pay awsome gti or anyone else over 200 quid
    is there a way to source the parts needed ( stalk etc )#
    and to get a guide how to do it??
    rconn you must know :)
  2. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group s tronic S-line owners group
    4,043
    789
    there was a very good write-up in this section do a quick search.
  3. Broken Byzan
    13,244
    468
    What car is it, diesels are easy, as they are DBW, most everything else needs a collection of parts to complete
  4. RobMorris
    RobMorris Member
    539
    10
    Im interested in this also for mine..
  5. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 saloon Team Akoya TDi
    15,166
    1,126
    Do search, I did a howto on it and so did someone else.
    Diesels are easy, like Aragorn said, due to their drive by wire.
  6. Geeman
    Geeman Low Life
    1,318
    I've just got the DBW cruise cable from Kufatek.
    I already had the stalk (A8) for my old 1.8T... so maybe on Sunday I'll get it fitted.
    Later 1.8T's and S4's are DBW, so it's just a case of replacing the stalk and wiring it in.
  7. tangerinedream
    249
    mine is 1.8t but is aeb so drive by wire any one got part no. needed and link to write up, thanks
  8. ScottD3
    15,166
    1,126
  9. tangerinedream
    249
    thanks mate just need part numbers now :)
    i swear ive seen an easeier write up thou ???
  10. olds_kool
    olds_kool Active Member VCDS Map User
    1,094
    15
    t/dream your car will be dbc, aragorn managed it on dbc but part list is a lot more than stalk and harness
    any one with dbw ive got a stalk and harness for sale, open to offers
  11. Broken Byzan
    13,244
    468
    Let me know what you are looking at mate.
  12. ScottD3
    15,166
    1,126
    There is.
    Mine is different cause I used a stalk from a A6/A8 I think.
    It says it all in the thread, I think. lol
  13. Geeman
    Geeman Low Life
    1,318
    My mate Ben used an A8 stalk (as I gave it to him) on his S4 and it was straight plug & play.
    Mine's the exact same stalk, so I'm hoping mine will be as simple too.
  14. PAULF
    PAULF Active Member VCDS Map User
    712
    66
  15. Broken Byzan
    13,244
    468
    aeb isn't dbw it's a cable throttle . only apu and anb are dbw iirc
  16. aragorn
    18,663
    878
    I made my own wiring harness for the cruise on the AEB.
    AEB cruise has a vacuum pump under the bonnet, a vacuum capsule and linkage attached to the throttle body, vacuum hose running from the pump to the capsule and also inside the car to vacuum switches on the pedals. There is also an ECU that sits above the glove box, and its connected to the brakes and various other circuits in the car.
    Its quite involved, and not something i'd suggest you take on unless you know your way around a wiring diagram. I had considered making up the looms for people, but you need connectors for various parts of the system and these get silly money buying new. I got the connectors supplied with the various components by the breakers yards i got the parts for, which is fine for DIYing the whole thing on one car, but not ideal if your wanting to supply the looms.
  17. tangerinedream
    249
    ah okay lol would awsome gti attemp it or is it that difficult its best not to bother?
  18. Broken Byzan
    13,244
    468
    I wouln't expect them to do it tbh. if they did parts could easily cost £200 used plus labour to fit etc.
    It's deffo worthwhile if you are handy at wiring etc yourself, otherwise not worth it
  19. tangerinedream
    249
    unfortunetley not :( unless someone wants to help :p
  20. Geeman
    Geeman Low Life
    1,318
    I was informed that the 'extra' wire on the Kufatec loom was an earth... not a power lead. No wonder mine's not working. Will have to undo it from the earthing point and fix it to a power point in the fuse box.
    Doh!
  21. Geeman
    Geeman Low Life
    1,318
    Done. Working. Happy. :icon_thumright:
  22. gary3306
    gary3306 Active Member
    989
    41
    Result! :sm4:
