cruise control stalk
nil538 May 7, 2013
  1. nil538
    nil538 Active Member
    499
    66
    Hi I've got a 2007 s3 and I've seen 3 cruise control stalk and the all say they will fit my car but all 3 have got a Different letter at the end of the part number can someone let me know if they will all fit ok thanks
    8P0953513D
    8P0953513B
    8P0953513F
  2. mike foster
    3,967
    They will all fit but it depends on what steering control module you have as to how/if they will work as CC
  3. Dannykn9
    Dannykn9 "Cruise My Ride" VCDS Map User
    1,123
    56
    You need either B or D, both will function fine.
    The F is for models 2009 onwards which have a different functioning full beam stalk.
    The difference between the the B and D is purely the stalk control diagrams. B would match your current full beam/indicator pattern where as the D will match 8P3 models 2008-2009.
    B, you can only buy second hand now, as Audi only sell the revised D and F.
    I have fitted countless amounts of cruise jobs, so take my word for it mate. If in London I could offer an install. PM me if interested mate.
  4. s3reptdi
    s3reptdi Member
    179
    What number do I need for a 2004 and 2005 cruise?
  5. jb0o
    jb0o North East Forum Moderator Site Sponsor Regional Rep VCDS Map User
    2,664
    118
    As Danny just said, either 8P0953513D or 8P0953513B.
  6. s3reptdi
    s3reptdi Member
    179
    Ok, Wasn't stated what years they were actually for, which one would go with my other stalk?
  7. jb0o
    2,664
    118
    Your other stalk?
  8. s3reptdi
    s3reptdi Member
    179
    It says the difference is the patterns that match up with the other stalk depending on the year, which number would match my other stalk to 2004/2005?
  9. jb0o
    2,664
    118
    Ah, the only difference is the picture on the stalk, so they both work exactly the same, but to keep it exactly OEM the dates are:
    2004-2006 - B
    2006-2009 - D
    But like also mentioned, you can't actually buy the B stalk anymore, you can only get it used. The D stalk is a much nicer stalk so I'd just get that one if it were me, I used it on my 2004 A3 and it was lovely.
  10. s3reptdi
    s3reptdi Member
    179
    Ok thanks, one last question whats the correct part number I need for the lower cowl?
  11. jb0o
    2,664
    118
    Only 1 for the A3 8P mate, its 8P0 953 512 A 6PS
  12. WALTO TDI
    WALTO TDI Member
    293
    12
    Im not sure which CC stalk i fitted but the push for full beam doesnt keep the full beam on?? but the full beam works if you push or pull it perfectly. any ideas???
  13. smurfworth
    smurfworth Well-Known Member Audi S3
    1,962
    551
    You say the D stalk is nicer, in what way is it different?
  14. jb0o
    2,664
    118
    Not as square and has a softer touch to it.
  15. biada76
    biada76 New Member
    Hello guys,
    I've got a Audi A3 my2010, on which I'm going to retrofit the cruise control (GRA - tempomat).
    I've bought the stalks (second hands on ebay, P/N 8P0953513F), but I'm unclear about the lower cowl.
    Second hand lower cowl can be easily found on ebay as 8P0953516A (specific for cruise control), but it will certainly fit model year 2003-2008.
    For the my 2009-onwards, can anyone confirm if I need the 8P0953516A or 8P0953512A ?
    I can't find any 8P0953512A as second hands.
  16. 1wheelonly
    1wheelonly cabriolet VCDS Map User
    2,386
    112
    It's very easy to just trim your own cowl, saves buying a new one
    I did my own on my TT
    Not perfect but very close and not easily seen
    joefarmboy likes this.
  17. biada76
    biada76 New Member
    thanks for the answer. How is it when fitted?
    Is your P/N 8P0953516 or 8P0953512? What model year?
