Cruise control retrofit.......but problem!
PiloTT Nov 16, 2008
  1. PiloTT
    PiloTT Member
    41
    Ok here is the deal...... I have fitted the stalk on my 2006 TDI, and coded the steering wheel ECU (MFSW) to include cruise. Measuring blocks relating to Cruise stalk were also checked for correct functionand all OK, BUT...... NO banana.... it does not work?????
    As for the wiring, I was pleasantly surprised that the wire (black/white) was already in place in the steering Connector plug and ASSUMED it ran all the way to the ECU.
    So, my question is.... Anyone with this experience confirm that the wire does indeed go all the way to the ECU as shown in the wiring diagram or is there an intermediate connector somewhere?
    Is there anything else that has to be coded with VAGCOM other than Steering ECU? Any other reason you can think of?:banghead:
  2. Stevie C
    Stevie C Stevie C
    154
    Give Mattandrew a shout, he helped out with mine although we did not have any problems... there is a small wire that needs to go up to and near the wiper motor but cant remember what its for!
  3. Stevie C
    Stevie C Stevie C
    154
    PS Matt has done the fit on the steering ECU too
  4. mattandrew
    mattandrew Member VCDS Map User
    977
    21
    Have you got the right version steering wheel ECU?
    If the wire is present in the plug there is no need to run any more
    I had issues with mine then realised I hadent told the car I had fitted cruise. You have to log into the engine module in VAGCOM
    log in to engine 01
    select Coding II - 11
    enter 11463 in to the coding
    this may help coding etc if you havent already got
    http://wiki.ross-tech.com/index.php/Audi_A3_(8P)_Steering_Assist#Special_Procedures
    If you need to buy a new electronics unit, make sure that you buy one that is compatible with your steering wheel slip ring. I spent quite a few hours trying to figure out why my new module didn't work properly, until it was found that it wasn't compatible..
    As far as I know, there are two different slip rings:
    1K0 959 653 A
    1K0 959 653 D
    If your steering wheel module (use vag-com to check) is 1K0 959 549 E or F, then you have the D slip ring. If the module is 1K0 959 549 or 1K0 959 549 A, then you have the A slip ring.
    The correct replacement modules with cruise functionality are:
    8P0 953 549 A (compatible with slip ring 1K0 959 653 A)
    8P0 953 549 C, D or F (compatible with slip ring 1K0 959 653 D)
    Hope this helps.
  5. PiloTT
    PiloTT Member
    41
    Well........ The steering wheel ECU is an "F" model so should be compatable. Just also tried the engine ECU coding as suggested but its still dead. There are also no VAGCOM errors listed anywhere on the car :crying:
  6. NHN
    29,328
    1,708
    Yeah F basically does everything anyway, I just reinstalled vista so elsawin not up yet so cant check the schematics for yer, but given the F version I assume its a facelift 05 onwards model so when I check elsa I know what year.
  7. MarcQuinlivan
    MarcQuinlivan Active Member
    2,539
    これで、ここでは、少数の歴史と語ったが必要だ 無名の英雄 この土が削除されます ある人は、継承はされています 造幣局からの輸入 人々の多くがないのにネウルエウンイ 事実、この老いたहेごみमेरे 彼は帽子にゴミ収集した これは、うわっイレオルスがズボンです そして彼は、フラットに住んで協議会
    彼は'真のनानाである 大きな皿の後に起動チクヒギル 彼はउन्हें得ることができる職業を持って 彼は根が何उन्हेंデイジー電話
  8. mattandrew
    977
    21
    As marc says have you tested
    Is the wire definaely in the plug? It only had to run it from the back of the steering wheel ECU to the top of the engine bay, it was present the rest of the way
    might be worth trying the engine coding again just to make sure its accepted
    sorry cant be of any more help
  9. VRStu
    VRStu Just Looking VCDS Map User
    1,073
    You can check the MBV's in engine 01 to see if the functions of the CC stalk are working.
    I've erm fitted one or two CC's in my time and if the black/white is present at the steering controller it has always been fully wired to the ECU.
    Have you used the 11463 login as above?
  10. PiloTT
    PiloTT Member
    41
    Well guys, thanks for all your help. Its finally working!
    To be honest I still dont know where the problem was, all I did was recode the steering module back to the old code and then to the new one again (0002042) then do the engine ECU login 11463 again.
    Its great thought to see others taking time on this forum to help others.:rock:
  11. VRStu
    1,073
    Probably the login then.
  12. AudiFan7
    AudiFan7 New Member
    26
    Is that module: 8P0 953 549 A compatible with slip ring 1K0 959 653 ?
