cruise control problem
hades- Feb 3, 2013
  1. hades-
    9,482
    646
    cruise not working
    checked brake and clutch switch in VCDS both working
    no codes
    any ideas ?
    TIA
    A4 1,8T cab
  2. NHN
    29,576
    1,779
    Have you checked the steering cu measuring blocks to see if its seeing the cruise switch buttons/movements 100%?
  3. hades-
    9,482
    646
    checked in 066
  4. NHN
    29,576
    1,779
    Unless wire to ecu has been damaged, then you sure the brake/clutch switch is definitely not at fault, you could try iirc connecting wires together to take switch out of equation for now, just to be 100% sure, anonomolies & all.
  5. hades-
    9,482
    646
    yeah i was gona do that but to cold out there today
    ill prob just get a switch and try it
    wheres the wire to ecu ?
  6. NHN
    29,576
    1,779
    Goes from steering cu to ecu, maybe via a connector aswell.
  7. hades-
    9,482
    646
    NHN just been playing again
    in field 2 in 066 its all spot on
    but in field 4 in 066 when i put the CC switch on it shows a 1 at the end
    but pressing the button resume acc deacc dont show anything they stay at 000001 then when i switch the cc stalk all the way back it shows 000000
    does the car have to be moveing to show that part ?
  8. NHN
    29,576
    1,779
    Usually when its coded, fitted etc, you can see all button/stalk signals via the measuring blocks when stationary, is this a retrofit or just yours has stopped working?
  9. hades-
    9,482
    646
    fitted about 3 mth ago
    been working perfect
  10. hades-
    9,482
    646
    can it be checked in anyoutput test ?
  11. NHN
    29,576
    1,779
    Unless the modules got a problem, all A4's I've done I always test stalk functions fully before fitting wheel/airbag back anyway, so if its not showing all the stalk functions, then somethings up either with stalk, steering module or the switches in footwell, cant be allot else.
  12. hades-
    9,482
    646
    but even if the brake or clutch switch was broke.
    would the the stalk functions still show in 006 ? field 4
  13. NHN
    29,576
    1,779
    Well this is the question tbh, if the switches are broke, do they stop the registering of stalk actions, afaik no, as the measuring blocks take straight from the module you're in as such, not via the switches, but we're talking german logic here, just remove switches, do a temp job on the wires to simulate the switches, then test, its not that cold out there fella lol.
  14. hades-
    9,482
    646
    thanks you
  15. Wrath
    Wrath Well-Known Member
    1,196
    42
    I've had a clutch switch problem twice and everything registered correctly in VCDS.
  16. hades-
    9,482
    646
    i know that can happed
    its just im not geting anything in 006 field 4
    im just gona unplug and wire it across to try
