My car has the stork but im beginning to think its not connected or programed? No amount of fiddling with it seems to do anything lol i might be being daft and it might be simple but i cant do it haha
A scan does not show a faulty clutch switch you would have to look through measuring blocks to check
To operate the cruise you have to have the stalk in the on position which is pulled towards you you will feel it click in then you get to a speed above 20mph then push the center button
If it doesn't work then you have a problem which is more then likely the clutch switch
If you can't get it scanned then remove the trim which covers the area where the switch is remove the plug from the switch and short the plug with a piece of wire and try the cruise again if it works you need a new switch at around 15 quid
How wud i get it scanned? Im guessing not every obd scanner can go so deep into the programms. Is it just average joes with the software on their laptop?
