Cruise control fitting?
thwaitesy Dec 16, 2012
  1. thwaitesy
    thwaitesy New Member
    13
    Hi is there Anyone around the watford/ herts area that can fit the cruise control for me i have the parts thanks
  2. Boydie
    Boydie S3 8V DSG VCDS Map User
    3,411
    556
    The fitting of the unit is pretty easy, you need someone to do the coding on VCDS/Vagcom.
    Disconnect the battery
    There are two spline/torque screws in the back of the steering wheel to release the airbag, remove them.
    Disconnect the airbag
    There is a spline holding the steering wheel in place, remove it and wheel will come off.
    Remove upper and lower cowel around steering column
    The existing stalk just clips in place so look on your new stalk for the clips and remove the OEM stalk.
    Clip the new one in place and reverse all the above.
    Vagcom is then needed to tell the car there is now a cruise option. Shouldn't take more than 30mins
  3. Gizmo68
    Gizmo68 VCDS & VCP owner in Kent VCDS Map User
    88
    Bear in mind that not all steering wheel controllers will accept CC, so depending what is currently fitted you may need the controller as well.
  4. Dannykn9
    Dannykn9 "Cruise My Ride" VCDS Map User
    1,123
    56
    Give me a PM if interested fella. I am only in Enfield so not too far. Have fitted for many on here.
  5. MrLapou
    MrLapou Well-Known Member
    1,233
    121
    Not quite as simple as mentioned as above. Took me about an hour together with some research on the web.
    First check which module is fitted. VCDS will scan and give info.
    If ok, proceed as above in i.e. disconnect battery leave key in ignition with steering lock off, before removing airbag.
    Clock spring unit needs to be secured/stopped from rotating before removal. Then a module below the steering column requires to be unplugged. It's a tricky job as one clip is hidden round the back and other requires a 1.5mm rod to be put through a small hole in the front, so clip can be undone. Two controller modules then need programming vis VCDS.
    If you feel your not confident. best leave it to someone in the know. Few members on here are ace at CC installs.
  6. avvy786
    avvy786 Member
    55
    Dannykn9 fitted the cruise control in my S3 on friday mate, done a professional job and ensured was working correctly before leaving - would recommend him mate :)
  7. Cruiser89
    Cruiser89 Advanced In Car Tech Site Sponsor
    1,484
    221
    Go with Danny bud! He's a top guy and has done quite a few on here.
  8. thwaitesy
    13
    how do i pm? trying to contact danny. i could do it myself i have the tools but not worth me doing and getting it wrong plus i need vagcomi have a friend with a edition 30 but dont trust him on my car
  9. mike foster
    3,967
    Danny - PM the guy as he's having trouble getting to you !
  10. thwaitesy
    13
    i may have done it now sorry knew to the forum cheers
  11. Dannykn9
    1,123
    56
    I did send you a message earlier mate, but I have now replied to yours.
  12. thwaitesy
    13
    sorted!
