Cruise Control fitting question
SuperV8 Jun 18, 2013
  1. SuperV8
    SuperV8 Member
    70
    12
    Hi all,
    Looking into fitting cruise control to my 1.9tdi quattro B6. Will fitting the hardware without plugging it into VCDS cause a problem?
    The reason I ask is I was thinking of fitting the control module and switch on my drive but then will need to drive to someone who can re-program via VCDS.
    Thanks,
    Tom.
  2. Mike.M
    Mike.M Well-Known Member
    2,510
    170
    Should be fine but not work as the ECU will not be looking for it as you would not have programmed it yet.
  3. SuperV8
    SuperV8 Member
    70
    12
    Ok thanks, I understand it wouldn't work, just checking the car would still work until I can get it plugged in.
    Tom.
  4. Stu-pid
    Stu-pid Member
    84
    It will all work fine as that is what I did DIS stalk.
  5. Mike.M
    2,510
    170
    Will be fine
  6. Audi Doodah
    Audi Doodah Active Member
    377
    35
    You'll no doubt have ABS/ESP and air bag warnings so drive safely!
  7. stu_m
    stu_m Well-Known Member VCDS Map User
    1,441
    as above you will have some warnings
    I had a member come to me for coding the cruise after he fitted it and he drove about 100 miles
