Cruise control fitting issue
Turkster Mar 25, 2010
  1. Turkster
    Turkster Bro.Paul 2.5TDI Quattro Sport
    2,800
    50
    right got all my cruise control parts fitted, Took the car to Audi to have it coded, They cant code it as the horse shoe part is not compatible with my car, its the one Ending with "Q" I was not charged for the time as they are rather good to me at my local main dealer,
    But when i was doing the hard wear upgrade i took all the old parts out and found the horse she part was already in place, it just needed the cruise control stalk adding, So the Audi tech said to put the old one back in and just fit the stalk and then have another bash at it,
    failing that they would need to order in the right part number for my car from the parts dept,
    Have i or they missed something out here?
  2. AudiLeon
    AudiLeon Well-Known Member VCDS Map User
    2,246
    189
  3. Turkster
    2,800
    50
  4. AudiLeon
    2,246
    189
  5. 1wheelonly
    1wheelonly cabriolet VCDS Map User
    2,385
    112
    Q should work with cruise
  6. quattrojames
    14,050
    578
    In Like a James Bond does Top Gun?
  7. 1wheelonly
    2,385
    112
    i see your on the ball again tonight james lol
  8. Turkster
    2,800
    50
    :applaus:
  9. Turkster
    2,800
    50
    The horse shoe part that was already in the car has a "F" on the end, any good?
  10. 1wheelonly
    2,385
    112
    dont think so mate, the q should be ok though
  11. AudiLeon
    2,246
    189
    As sai above, no good it doesn't support the required features.
  12. blackpool1974
    blackpool1974 Member VCDS Map User
    138
    I think you have got mixed up with the modules
    What is the complete code of the module you have taken out as I cant find one with "F" revision
    The one you have put in I assume is 8E0 953 549 Q which might not be for your car model
  13. A4 nut
    A4 nut Member
    351
    I have one ending in N if you want to trade for the Q this supports cruise
  14. Turkster
    2,800
    50
    now this may be the way forward!
  15. blackpool1974
    138
    Bit like saying I will swop you my 50p for a £5 note :lmfao:
  16. Turkster
    2,800
    50
    I hear what your saying,
    BTBH im told by my local main Audi dealer that i need "N" to get my cruise control to work with my car with there Audi system, Audi will only charge me £20 to code the "N" bit if it works, and the "Q" will cost me £50 and a trip to hemel hempsted to get loaded with VAG COM by a cruise control so called expert,
    So really im not going to lose anything by trying, Should the "N" not do the job then i will have to keep the "Q" and send the "N" back,
    At the end of the day all i want is the cruise control thing to work, But the strange thing is i most probably wont use that option very often apart from when i do my yearly drive to Turkey and back,
    :icon_thumright:
  17. A4 nut
    A4 nut Member
    351
    WHY they both go for £45 on ebay he does not want a fbmfsw i do he wants an N i want a Q is this not a fair trade do i need to offer money as well is the Q 10 times better than an N?
  18. 1wheelonly
    2,385
    112
    NUT, id say they both have the same value to each other, seeing as both of you NEED the others, makes sense to me !
    TURK, is the so called expert at hemel hazzy days by any chance lol ??? stay away ! greedy twat that states hes fitting stuff he aint etc !!
  19. Turkster
    2,800
    50
    All i want is the cruise controle to work, i dont have the volume switches on my s-wheel, :icon_thumright:
    yep, hazzy dayz, whats he been up to?
  20. chrisash32
    chrisash32 Member
    573
    Have you got VAG-COM??
    If you have drop me a PM with a full Fault Scan...
    I have the Q module in mine and it works fine, so you shouldn't have any problems either.
    It sounds like you just need someone with VAG-COM to code it up correctly if you don't have it yourself.
    Chris
  21. blackpool1974
    138
    If for any reason you are near Watford on Monday I can code your "Q" for you, I have an "N" aswell if that didn't work.
    Like everybody else has said:
    "N" is cruise
    "Q" is cruise and multi function steering wheel
  22. 1wheelonly
    2,385
    112
    just swap and both of ya are sorted
  23. Turkster
    2,800
    50
    I dont have VAG COM at the mo, but i may just get it as it seems it can become a very useful tool to have,
  24. 1wheelonly
    2,385
    112
    nige ( NHN ) on here is your best bet mate, hes the cheapest too, full genuine one special delivery and full support
  25. AudiLeon
    2,246
    189
    MFSW works with N doesn't it? Just Q supports heated steering wheels?
  26. A4 nut
    A4 nut Member
    351
    If we swap i can program it for you, thought you had vag-com any way the offer is still there
  27. stevereid
    stevereid Member
    254
    Ok, I want to join in on this :) I'm looking for a SWCM for my A4 B6 so I can get cruise installed..so If anyone has one they want shot of.. please pm away :)
  28. mattyboyc
    mattyboyc B6 Veteran Audi A4 Audi Avant Owner Group TDi
    1,994
    217
    OK guys,just to throw a rather large spanner in the works i have one here part # 8E0 953 549 P, i take it i have a"p" module so what the bloody hell does that support?:confused:
    Thanks in advance and as i say sorry to hijack:icon_thumright:
  29. stevereid
    stevereid Member
    254
    I already had hijacked it Matt..asking for a SWCM if anyone had one :)
  30. mattyboyc
    1,994
    217
  31. Turkster
    2,800
    50
  32. mattyboyc
    1,994
    217
    Seems strange as it's being sold as a complete unit, i think we all need someone to clarify what will and what won't work:icon_thumright:
  33. AudiLeon
    2,246
    189
    • Lowline
      • Supported Steering Wheels: Standard Steering Wheel (4-Spoke)
      • Supported Features: Trip Computer (does NOT support Cruise Control!)
      • Part Numbers: 8E0-953-549-F 8E0-953-549-S
    • Midline
      • Supported Steering Wheels: Standard Steering Wheel (4-Spoke), Sport Steering Wheel (3-Spoke), Multi-Function Steering Wheel
      • Supported Features: Trip Computer, Cruise Control
      • Part Numbers: 8E0-953-549-L, 8E0-953-549-N
    • Highline
      • Supported Features: Trip Computer, Cruise Control, Steering Wheel Heating
      • Part Numbers: 8E0-953-549-M, 8E0-953-549-P, 8E0-953-549-Q, 8E0-953-549-R
  34. mattyboyc
    1,994
    217
    What a star, thanks very much:icon_thumright:
  35. vrbob
    vrbob Thats no Moon, Thats a space station!
    2,375
    171
    Cool so the N version does support MFSW thats good to know for future modifications as that is the SWCM i am using when fitting my DIS.
  36. blackpool1974
    138
    Sorry to wee on your parade, the "N" does support MFSW but only the B6 one
    "Q" is the lowest that supports the B7 and others. you also will need a new slip ring aswell with newer wheels
  37. mattyboyc
    1,994
    217
    Nice wheels:eyebrows:
  38. 1wheelonly
    2,385
    112
    just to comfirm what blacky said, i have a B6 cab and i had the older style multi wheel which he posted above, when i upgraded to my newer wheel and added cruise, i had to change both my module and my slipring as the older b6 ones, although i had the function already were NOT compatible.
    heres my new one along with cruise.
  39. vrbob
    2,375
    171
    Ahh ok only B6 MFSW`s thats ok they are cheaper to buy but dont look very nice.
    To be honest i dont think i will do the MFSW upgrade but at least i know what to look for if i do.
    Cheers guys
  40. AudiLeon
    2,246
    189
    Nice bit of info there. Thanky uo for the correction. saves me making a silly mistake lol
