creeking when going over speed bumps
s3gazz Oct 20, 2010
  1. s3gazz
    s3gazz Well-Known Member
    1,376
    99
    hi every time i go over speed bumps i get a creeking nose at front
  2. quattro1
    quattro1 Member
    639
    jack it up and see if the springs are in one piece, failing that id say lower suspension arm bushes
  3. superkarl
    superkarl MAN OF STEEL
    9,398
    2,376
    our cars are old, worn bushes and libnks are normal, so noises are expected really. as above, check everythin for play, replace and upgrade as need be.
    my car is off the road soon for the following:
    cv boots
    inner driveshaft boots
    bottom ball joints
    front wishbone front bush
    front wishbone rear bush
    front top mounts
    anti roll bar bushes front and rear
    and possibly rear wishbone bushes.
    all this to combat irregular noises, and to bring back some new car feel. failing all this, new suspension.
  4. FazS3
    FazS3 Member
    867
    How much is that setting you back matey?
  5. Nilz
    11,317
    870
    Sounds like the ARB Bushes that are gone mate, its a very common issue on our cars...
  6. superkarl
    9,398
    2,376
    havn't added it up yet to be honest. i've done it quite cheap though. some stuff i've gone oem, for quality reasons, and things like front wishbone front mounts i've gone powerflex. some things, top mounts for example, arn't oem, but the quality is dam impressive, dont be scared to not get oem if im honest. obv some areas will benefit. when everything is delivered, and i've added other related parts il add it up. and it allll adds up!
    i forgot to add transmission oil to my list, but that wasnt relavent to noises.
  7. scoobyra
    scoobyra It's not f@cking ORANGE!!!!!
    798
    It is when your gearbox sounds like a tired 2 year old after a whole days shopping! LOL
  8. superkarl
    9,398
    2,376
    ha thankfully mine doesnt
  9. JD09
    JD09 I'm not modding, I'm improving VCDS Map User
    3,096
    46
    Going down the same routes as you Karl, as I think we've mentioned before. So far had rear shocks, rear springs, front droplinks and front wishbones (new unit, so all bushes and ball joints).
    To come next month, front shocks and springs, top mounts and rear droplinks.
  10. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    14
    Mine does the same. When i had my coilys fitted my mechanic told me my wishbone bushes had gone.
  11. Nilz
    11,317
    870
    Apparently they have a sleeve in them, which is a tiny bit of plastic, and once that goes thats what causes the noise.....i think
  12. superkarl
    9,398
    2,376
    well my first port of call is the bushes and the likes, alot cheaper than forking out for shocks and springs straight away. plus when im replacing them il give the shocks a good checking over to see how they are, whether they need replacing, i do have my suspisions though. but with all bushes, top mounts and maybe drop links now you've mentioned it, its gonna be such an improvement. something everyone should consider!!!
  13. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,255
    355
    mines all getting fitted next week! :)
  14. JD09
    3,096
    46
    I had two leaking rear shocks, breaking springs and I've already had a front go on me. So I'm guessing that's them telling me to replace ;)
