Creaky mmi screen
Jenks108 Aug 21, 2013
  1. Jenks108
    Jenks108 Member
    43
    Hi,
    Has anyone else had this problem? After 4000miles the mmi screen has begun creaking and squeaking when in the up position, even on quite smooth roads. Obviously not a huge problem, but not very Audi-like either....so its going in to tighten some screws on Friday.
    Wondered if everyone's is doing this?
    Cheers.
  2. BigD289
    BigD289 Member
    104
    13
    I've noticed the same, its quite annoying since everything else is so well built!
    I would be interested to know how you get on.
  3. BigD289
    BigD289 Member
    104
    13
    Jenks108, did you get yours fixed, did it take long? Ours is squeaking more than ever so I guess its a trip to the dealers.
  4. Chappy
    Chappy Call me Dan! Audi A5
    471
    25
    Mine makes the odd noise now and then, although I thought it was the B&O speaker grill behind it.
  5. JayDZS*
    JayDZS* Member
    64
    I get the odd rattle and creak every now and again but no idea where it's coming from!
  6. BigD289
    BigD289 Member
    104
    13
    Mine is definitely the MMI screen, if I hold it it goes away
  7. Simon Ruddock
    Simon Ruddock New Member
    Same problem with mine, started at around 5k on the clock, only notice it when the music is off though, and with the B & O system its rarely off so not bothered me enough to take in to get looked at.
  8. snakehips
    snakehips Well-Known Member
    735
    261
    When I first saw it I figured it was inevitable that this one moving part in the dashboard was bound to end up creaking, and creaking in the car drives me nuts! Hope they have a fix before I reach 4K miles...
  9. SJW
    SJW Active Member
    209
    65
    Yes I had this issue. I thought it was down to heat being generated around that moving part causing the casing to expand and contract giving rise to the creaking sound. It has settled down now and I have done 6250 miles. If It becomes noticeable again I will have it looked at. Seems okay now. Perhaps just needed time to settle down.
  10. Johnes
    Johnes New Member
    I have exactly the same issue.that's really annoying! Is there any update?
  11. Coxy234
    Coxy234 Member
    71
    23
    I had it the one day and it was doing my head in. I pushed the top and the screen actually popped back in to the dash. I've not heard it since. I do play my music loud tho.
  12. Johnes
    Johnes New Member
    It's really annoying.It's like,it's the only thing I'm hearing now while driving :) I couldn't find any solution.You mean you pushed the screen from top towards the front window?
  13. Coxy234
    Coxy234 Member
    71
    23
    I just put pressure on the top. Not towards the window. Not a lot of pressure, I doubt it has fixed it to be fair, it will probably come back at some point.
  14. cuke2u
    cuke2u Well-Known Member TFSI Owners Group Audi A4 S-line owners group saloon
    5,051
    1,375
    Is this issue only with the larger screens?
  15. Leeber
    Leeber Active Member
    234
    98
    A bit OT I know but can I ask if the screen pops up whenever you start the car or only when desired? If the former can you set it to stay down unless required?
  16. JohnM100
    JohnM100 #teamSepang VCDS Map User Gold Supporter
    951
    394
    Screen always pops up at startup unless MMI is switched off (so no radio/SD card music etc)
    There is a button to retract the MMI display with the radio/media card still working but that only works until the next time the ignition is turned on when the display pops up again automatically.
    It does not remember the "audio on but keep MMI retracted" at next start-up.
    John.
  17. Leeber
    234
    98
    Thanks, I thought that would be the case. I wonder if that can be changed in VCDS?
  18. cemerson
    cemerson Well-Known Member Team Cosmos quattro Audi A3 S-line owners group TDi DSG
    4,360
    1,060
    Being able to remember the screen position between ignition off/on would be pretty nice. The car does it for a lot of other things so not sure why it wouldn't for this.
    Same goes for music paused or not - music always starts even if you paused/muted it last time you turned off the car.
  19. Johnes
    Johnes New Member
    Is anyone find a solution? those creaks makes me mad!
  20. Johnes
    Johnes New Member
    Thanks,I will try it.I hope it works
  21. Aran383
    Aran383 Active Member
    106
    89
    I had the same problem, so took it into audi back in September and they changed the mmi screen and the unit, haven't had any creaking since then!
  22. chute1860
    chute1860 New Member
    12
    Took mine in to Derby Audi on Monday 24.03.14 for creaking mmi screen. They took it out and lubricated it, all seamed well until today now the creaking is back, very annoying.
  23. Jenks108
    Jenks108 Member
    43
    The creaking on mine came back too, but now it's cured itself.
  24. BigD289
    BigD289 Member
    104
    13
    Apparently Audi changed our mechanism but it seems to have come back. I think it might be worse on sunny days. Most certainly it wasn't too bad over winter but now the sun has come out its getting worse again. Its so annoying sometimes I have to hide the display!
  25. chute1860
    12
    Pressing the screen down by hand silenced mine for a few days. This has been my only issue with the car since owning it apart from someone scraping by bumper whilst parked
  26. pat15312
    pat15312 Well-Known Member
    530
    252
    If you let the dealership p*** about with the dash it will most likely come back worse - got personal experience with this...
    I suggest you put the music up louder mate.
  27. snowfree52
    snowfree52 Full LED baby !
    522
    125
    43
    you can't put it louder than the noise
    Anyway, I went already twice to the dealer, first time it went silent for 2 months then came back. This time they had a specifically made grease (what they said) by Audi Germany for this particular problem on the GPS. they know what part is causing it.
  28. PDA3
    PDA3 Member
    65
    Sounds loose! What's that other item you have attached to the dash too?!
  29. snowfree52
    522
    125
    43
    something I had for my phone, but the noise comes from the GPS screen
  30. papaspeter
    papaspeter New Member
    10
    I have the the same noise about 20 days now at 22000km. I will ask to replace my screen, since it is within the warranty time.
  31. BigD289
    BigD289 Member
    104
    13
    Let us know if this fixes the problem!
  32. chute1860
    12
    Took my A3 back to Derby Audi again today, fingers crossed they cure it.
  33. BigD289
    BigD289 Member
    104
    13
    It would be great to hear your feedback and whether or not they fixed it!
  34. chute1860
    12
    Got my A3 back yesterday, early yet but all seems well.
    fitted me a new mmi mechanism then rigorously tested it.
    Service and loan cars at Derby Audi very good even gave me a bottle of champagne for not fixing it the first time.
    hope this helps
