Creaking noise when accelerating right from standstill
JPK Jun 2, 2013
  1. JPK
    JPK Active Member
    303
    This existed when the car was stock and still exists.
    I have replaced engine/trans mounts, strut mounts & bearings, shocks, springs, tie rods, tie rod ends, ball joints, front/rear control arm bushes, sway bar end links, brakes and have tyrolsports deadset subframe kit.
    Any ideas? Doesn't seem like much else to replace other than axles/CVs and wheel bearings?
  2. coreythorny
    coreythorny Active Member
    463
    74
    Might sound daft, feel daft saying it, but have you checked the heat shields aren't touching the back of the disc or look like they might be a bit close?
    on my old car these used to cause me issues, slightly bent it back and was sorted. Probably not just a 2pence worth.
  3. JPK
    JPK Active Member
    303
    Open to any suggestions. Will have a good look at that tomorrow. It's weird that it only does it when accelerating right from a standstill - coming out of a street and turning right.
    Doesnt do it when slowly turning in a carpark or turning at speed. Have tried the usual bad CV tests (reversing full lock etc), no issues there.
  4. coreythorny
    463
    74
    I believe a lipped disc can also cause a noise on lock but you say you've changed them so.
  5. max69vk
    max69vk Active Member
    862
    57
    Could be your steering rack itself, it's quite a common issue.
  6. JPK
    JPK Active Member
    303
    Hope it isn't steering rack. It isn't really exhibiting usual symptoms for a faulty steering rack however.
  7. rick89
    rick89 New Member
    25
    Was this issue ever solved? I have something similar.
  8. Johnny Bravo
    Johnny Bravo 6+1 Gears Bronze Supporter Audi A3
    898
    69
    I also have a knocking when turning left and back to straight position. Nothing when I turn right. In my case I think is the left hand side ARB bush. I came to this conclusion after removing the tie rods and turned the steering wheel again. There was no noise. Now I'm waiting for new H&R bushes to replace both of them and hopefully getting rid of that noise. After spending almost 7,000 euros on new suspension, ARBs, control arms, brakes etc. is very frustrating to have this problem...
  9. SAiLO
    SAiLO Well-Known Member VCDS Map User
    1,074
    61
    Brakes binding?
