crankshaft sensor location help
shreddedbrahhh Oct 20, 2013
  1. shreddedbrahhh
    shreddedbrahhh New Member
    27
    just about to change the crankshaft sensor and cant seem to find it.
    audi a3 2006 s line 170.
    if anyone can tell me where it is or an image of the location would be a massive help .
    thanks all
  2. towcestervag
    towcestervag Member VCDS Map User
    165
    its located behind the oil filter/cooler housing
    between the engine and gearbox joint about 40mm up from the front casing bolt
    you need to remove the oil filter housing assy to gain access
    you will need a ball end 5mm allen key
