crankshaft seal leak, ADVISE NEEDED PLS
khalil Dec 18, 2008
  1. khalil
    khalil Member
    774
    hi all i have a ongoing oil leak, so had a mechanic look at it he took lots of bits off and found that its the crankshaft seal thats leaking,(when i say leaking a slow leak, meaning when i leave the car overnight you can see like a 2p size oil on the road, thats only because i have the under tray off), as you know to replace that you need to take off the timing belt along with lots of other bits and it is quiet pricey, the mechanic said that it will not cause problems with that oil leak and can wait till your timing belt is due and than change the seal, whats your guys advise
