rodenal
- Joined
- Oct 22, 2006
- Messages
- 1,992
- Reaction score
- 0
- Points
- 36
Car was running like a dog today, spluttering and not revving properly so stuck it on vag com and got the following:
VAG-COM Version: Release 311.2-N
Chassis Type: 8L - Audi A3/S3
Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
Address 01 -------------------------------------------------------
Controller: 06A 906 019 D
Component: 1.6l R4/2V SIMOS HS2153
Coding: 04000
Shop #: WSC 00000
1 Fault Found:
00515 - Camshaft Position (Hall) Sensor (G40)
03-00 - No Signal
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 1J0 907 379
Component: ABS ITTAE 20 GI V00
Coding: 03604
Shop #: WSC 06435
No fault code found.
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8L0 919 910 A
Component: AB-KOMBIINSTR. VDO D07
Coding: 08442
Shop #: WSC 00000
IMMO-IDENTNR: AUZ7Z0T0031761
1 Fault Found:
01176 - Key
07-00 - Signal to Low
Address 35 -------------------------------------------------------
Controller: 8LO 862 257 A
Component: ZV-Pumpe, DWA
Coding: 01320
Shop #: WSC 06313
Address 45 -------------------------------------------------------
Controller: 8L0 951 173
Component: Innenraumueberw. D01
Coding: 00001
Shop #: WSC 00000
End -------------------------------------------------------
Camshaft position sensor is the only one that concerns me, is this just another name for the crank sensor? Also what does no signal mean, that its bust or that it may have become disconnected?
The car has this fault intermittently, sometimes it will run rough for a day or two then be fine for months, cleared this same code once 6 months ago and its never came back until now,
any advice apreciated
Coding: 04000
Shop #: WSC 00000
1 Fault Found:
03-00 - No Signal
Readiness: N/A
Coding: 03604
Shop #: WSC 06435
Coding: 08442
Shop #: WSC 00000
1 Fault Found:
01176 - Key
Coding: 01320
Shop #: WSC 06313
Coding: 00001
Shop #: WSC 00000
