Crank - flywheel info needed
jcb Feb 14, 2007
  1. jcb
    jcb Active Member
    4,132
    13
    Does anyone know (i.e. actually seen) the bolt pattern for RS4/S4 crank to flywheel compared to that of a 1.8t crank to flywheel?
    Is there any reason I couldn't use an RS4 clutch and (if needed) Flywheel on a 1.8t? both B5 chassis, both inline,
    I can;t think of one off hand but thought I would seek some advice.
    I want an uprated clutch with as close to OEM feel as posisble.
    RS4 is rated up to 400+lb/ft which is more than enough for me and will keep the dual mass OEM unit.
    any help would be great
  2. macca
    macca Member
    525
    i'm only guessing they are different as i thought ecs tuning say they modify the flywheel to take a s4 or rs4 clutch, is the s4/rs4 flywheel bigger diameter?
    i think rs4 clutch is the way to go though.
    looks like you and i have the same things planned for our cars at the moment.
  3. jcb
    jcb Active Member
    4,132
    13
    that why I think an RS4 flywheel is the way forward, can't believe they would have a different bolt pattern between flywheels.
    can understand why an rs4/s4 clutch would fit on a 1.8t flywheel though.
  4. Caesium
    Caesium My BM is fixed! VCDS Map User
    4,879
    I would think as the RS4 has a bigger engine the flywheel is likely to also be bigger and with more mass, if you fit a flywheel with larger mass onto a smaller engine, it wont run right, and will probably be more sliggish to accelerate.
    Just go for an uprated clutch to fit your existing flywheel, maybe a part ceramic one with an uprated pressure plate.
  5. PhilR
    PhilR One Ate Tea
    332
    How much power are you aiming for ? my mate has a mk2 golf with an AGU 1.8t with IHI turbo running about 350 and he uses a standard clutch.
    Suppose it has less weight to propell though
  6. jcb
    jcb Active Member
    4,132
    13
    he is not 4wd either, only point of slip on 4wd is at the clutch.
    I haven't found a decent aftermarket clutch that isn't a stupid price or that requires a larger left leg transplant.
    Doc put me in touch with Southbend and they are around $600
    any thoughts on other options?
