Crank Case Vent Valve Hose
ollie2013uk Jun 9, 2013
  1. ollie2013uk
    ollie2013uk Active Member VCDS Map User
    139
    37
    Hi all,
    Does anybody know the hose part number that connects the crank valve to the turbo inlet pipe?
    I cant seem to find it anywhere!
  2. <tuffty/>
    21,155
    3,835
    The plastic one that comes up from the block to the cam cover 3 way hose?
    Part numbers are normally on the parts them selves... VAG are pretty good at that...
  3. ollie2013uk
    139
    37
    Thanks tuffty, the car isn't with me at the minute, I thought I'd just ask. No its the hose that goes straight into the TIP then to the crank breather.
    I'll have a look tomorrow if no one knows.
  4. <tuffty/>
    21,155
    3,835
    No such pipe unless yours has been faffed with... there is a plastic elbow that comes out the top of the oil filter housing... this goes to a rubber t-piece that has a PCV valve for the inlet manifold, the other end connects to a plastic or metal pipe that goes to the 3 way rubber hose coming off the cam cover outlet... the third outlet of this 3-way hose connects to the 'hocky puck' PCV valve before connecting to the TIP... depending which car/year you have there will be slight variances in the hoses etc but the layout is the same regardless...
    This may help...
    https://www.google.co.uk/search?q=1...XO6W10QXk14C4Cg&ved=0CDIQsAQ&biw=1032&bih=912
  5. ollie2013uk
    139
    37
    This is the pipe i was on about mate:
  6. SoljahofSensi
    SoljahofSensi Member
    91
    06A 103 817
    just happened to have mine to hand, recently changed mine, forge do a replacement if your that way inclined.
    ollie2013uk likes this.
  7. ollie2013uk
    139
    37
    Thanks, do you have a forge part number or link?
