Crackling through speakers :o(
Oranoco Aug 7, 2010
  1. Oranoco
    Oranoco Well-Known Member
    3,970
    405
    Getting really hacked off now. Everytime I start the car in the morning and the revs are above about 1500rpm I get an annoying crackle through the speakers, it doesn't make any odds as to CD or radio and if i use the Parrot hands free kit the crackle is also present. This leads me to thinking it's something a miss with teh cars electrics than the audio electrics.
    Any ideas gratefully recieved. I did take a lot of the car apart when did the timing belt, radiator and rocker gasket change so could I have disturbed something under the bonnet to cause this?
  2. andybnwc
    andybnwc Member
    752
    disconnect the parrot And any other external audio items if fitted see if that stops it
  3. millsy
    millsy Member
    55
    is it a standard head unit and speakers?then its probably down to a loose connection or a bad earth.or you have an after market head unit/amps/speakers etc,you need to trace back to locate the problem,i.e; play music quietly,disconnect individual speakers in turn and see if noise stops,remove fuses from amps etc.
  4. Rallyman
    Rallyman LPG Abuser & have VAGCOM Bronze Supporter
    213
    Had a funny noise from my stereo a while back, found that the earth lead on the rocker cover had come loose - same loom as the coil packs. you will probably find that there is an earth gone somewhere - or the stereo internal amps have started to die....
  5. Oranoco
    3,970
    405
    Stereo is setup so not to use the onboard amp, it's a sound processor only. Will double check the earth strap for the coil packs though, cheers :)
  6. Oranoco
    3,970
    405
    I owe you a beer, this was indeed the culprit it would seem. Must have not done it up completely when I had the car apart and it worked loose and had popped off. Will have to see in the morning for 100% but it's looking very promising
