Couple questions
Tank. May 12, 2014
  1. Tank.
    Tank. Member
    240
    Still looking at c6 avant 3.0 tdi's
    noticed theres some difference in power, some older are 221 bhp and around 2007 onward are 233bhp, are the mechanics of the engines exactly the same? Just different maps?
    also if i was buying a set of the lemans style speedlines can you fit offset fitments? Wider on the rear?
    maybe getting ahead of myself but found one i really like if i can strike while its still available
  2. a6_chris
    a6_chris Well-Known Member
    1,883
    160
    Earlier cars had/are more prone to bigger failures such as injectors or chain stretching/wear so best going 2007+ if you can afford to.
    You may want to have a look here which gives some examples of wheels and offsets - A6 C6 - The Ultimate Wheel Guide
  3. Tank.
    Tank. Member
    240
    Hmm thats a bit disappointing! The car ive found is 06 plate s line with 93k on the clock
  4. Tank.
    Tank. Member
    240
    Scratch that mileage check says 107k
