Couple of questions on my B6...
jdw88rm May 16, 2014
  1. jdw88rm
    jdw88rm Member
    172
    Evening guys,
    Just a couple of general questions - first one is, whenever I lock my car the hazard triangle stays lit for roughly 30secs before going out. Is this normal or does it indicate a fault?
    Second is, I want to remove my wiper arms to re-paint but after taking the nut off each one they're still stuck solid. Is there a special way or does it just take abit of brute force?
    Many thanks lads
  2. Mike.M
    Mike.M Well-Known Member
    2,510
    170
    1. Yes, this is normal
    2. Gentle rocking and a little wd40 or similar help to get them off.......well it does for me and had them off several times
  3. swarcup
    swarcup Well-Known Member
    1,326
    40
    Hazard light does that, many a folk has asked that question and as for the wiper arms they can be a bit stubborn, i gave mine a good wiggle and yuck to remove them.
  4. shaz
    shaz Member
    167
    Yes pal defo give the wiper arms a good pull once unbolted...
  5. ruffrida
    ruffrida Well-Known Member
    1,926
    313
    Pull wiggle, pull wiggle, slowly slowly catchy monkey and they will come of!!
  6. jdw88rm
    jdw88rm Member
    172
    Thanks guys!
  7. TheDriver
    TheDriver Active Member
    265
    Or if they're still not playing nice then buy a 3-leg puller tool. Save you damaging the splines on the mechanism with too much twisty-yanky. All these technical terms hey!!
  8. +1 to the puller tool makes life so much easier with these wiper arms
  9. GeoffDunk
    GeoffDunk Well-Known Member Team Panther Audi RS4 quattro Audi Avant Owner Group
    1,300
    392
    Ultimately this is the correct way of doing it, its caused by aluminum alloy against steel tapered shaft.
    DO NOT HIT NOT ON END OF THREAD WITH HAMMER!!!!! So many have done this and you will end up with a cracked windscreen!
  10. TheDriver
    265
    Also worth putting a tiny bit of copper grease or plastilube on the shafts too when you come to replace the arms, should make the job a bit easier next time round if you ever come to remove them again. :thumbsup:
    GeoffDunk likes this.
  11. ruffrida
    1,926
    313
    Oooo a good bit of lube lol
  12. TheDriver
    265
    HAahah, you like that Ads? :eyebrows:
    I'm sure you'll agree, when you want to pull one off you don't wanna have to fight with it (the wiper that is...!!!)
