couple of questions about A4
Effect Jun 21, 2009
  1. Effect
    Effect Member
    469
    I have an 09 A4 1.9TDI estate courtesy car whilst mine is in for a respray.
    The Air con wont work, it has dual zone climate control but whenever you press the ECON button the light stays on and I dont get any nice fresh cool air.
    Why might this be ?
    Also the cruise control doesnt work, I thought the reason for both of these might be that Audi have disabled them both but not sure. :S
    Regards
    James
  2. Johnytuono
    Johnytuono Member
    131
    ......try pressing the Auto button. As for the cruise control I think at some point you have pressed the brake pedal before it will enable.Sorry if this is the obvious. HTH
    JohnyT
  3. quattrojames
    14,050
    573
    Hi James
    The ECON button means economy, so when the ECOn light is illuminated it means the a/c compressor is turned off. This means that the heating/ventilation system will work just the same but with only ambient air being blown through.
    As mentioned, press AUTO and the ECON light will go off and the a/c system will (should) be working.
    I can't see why they would have disabled cruise, I am not familiar with the B8 system, but you will have to turn it ON, then press SET (or similar) to set your speed, then either touch brakes/clutch to cancel it (bad habit) or press CANC on the stalk. This will leave the cruise ON, but not SET - you would then just press RESUME to bring the car back to the preset speed.
  4. johnnythepie
    johnnythepie Well-Known Member
    2,242
    75
    pull the lever towards you to turn on.
    drive at the speed you wish to set the system to
    push the button on end of stalk in to store the speed
    to adjust the speed: accelerate to desired speed
    push button on end of stalk.
    this is the basic operation.To turn it off, press brake or pull lever towards you.
    Is there no manual in the glovebox????
  5. scoTTy
    scoTTy Active Member
    1,962
    There's no ECON button on the B8.
    It just says AC instead ;)
  6. quattrojames
    14,050
    573
    Must be a B7 courtesy car then?
  7. Effect
    Effect Member
    469
    sorry I was assuming it was a B8 as it is an 09 plate.
    I understand fully how the cruise control works as it is exactly teh same system as my bosses Passat, not bothered about that anyway as i wont need it.
    The air con is exactly the same as in my S3 apat from it being dual zone.
    The ECON light stays lit wether i press it after/before putting it on auto.
