Couple of problems
Kenzie Mar 20, 2010
  1. Kenzie
    Kenzie Member
    32
    Wonder if anyone could help here, first off when the car is cold, it starts first turn, but when its hot, it takes 5+ turns, any idea what could be causing this? Also, when the car reaches about 2000rpm it hesistates for half a second or so, any ideas on the cause of that?
    Any help much appreciated, thanks in advance :)
  2. motionlee
    motionlee Member
    98
    Knowing what car you have could help :idea:
  3. Kenzie
    Kenzie Member
    32
    D'oh! Sorry, it's a 54 plate 2.0tdi 140.
  4. mike foster
    3,967
    Don't know about the hesitation problem but the starting problem is likely to be caused by a dickie starter motor. This is a very common problem with this model and can only be fixed by a replacement unit.
  5. Kenzie
    Kenzie Member
    32
    Does it get worse over time do you know mate?
  6. mike foster
    3,967
    Sorry Kenzie, don't know the answer to that. There are loads of threads on this forum and others about the problem so, if you have the time, have a trawl through and see if they can help. Good luck !
  7. Kenzie
    Kenzie Member
    32
    Will have a looky, thanks for you help mate.
