couple of error's showing - need help :)
m8arx Jun 23, 2010
  1. m8arx
    m8arx Member
    176
    guys, since i got the turbo replaced on my S3, i've had a few error's showing.
    the first one is 16486/P0102/000258 - Mass Air Flow - Signal too low
    It's a brand new MAF, so i'm not concerned about this and believe it's a loose connection or something, so i'll be able to check this out.
    the second one is 17963/P1555 - Boost Pressure Control: Maximum Pressure Exceeded
    now, the car doesn't go into limp mode at all, it does seem a little "jerky" at stages when pulling away.
    The N75 doesn't have anything wrong with it, another has been tried and it's still the same. apart from boost pipe's causing a problem, is there anything it could be. the only pipe's that have been removed where the one's near and connecting to the turbo, nothing else, so i don't think any of the front pipe's would have been disturbed. anyone had this error before and how did you fix it (which pipe if it was a pipe problem?)
    third issue isn't with the engine, it's with the brake system/steering system. The traction control light is constantly on because of this error.
    00778 - Steering Angle Sensor (G85) Mechanical Failure
    The turbo was removed from the car by removing the subframe, exhaust and doing it from underneath the car. the steering wheel is very slightly off centre now. Is it a simple case of getting the alignment done, or is it a case of taking the steering wheel off and fixing/changing the sensor?
    any idea's / input would be appreciated :)
  2. m8arx
    m8arx Member
    176
    great stuff, cheers, i'll give that a try
  3. leshkin
    leshkin Hold my beer... VCDS Map User Gold Supporter Team Sepang Audi S3
    2,719
    1,618
    I think you picked a bad time to ask question with most people watching football :)
    As per wiki.ross-tech.com:
    16486/P0102/000258 - Mass Air Flow (MAF) (G70): Signal too Low
    Possible Symptoms
    • Probably no serious malfunctions
    • Loss of power
    Possible Causes
    • Wiring and/or connections (short circuit?)
    • Mass Air Flow (MAF) (G70) defective
    Possible Solutions
    • Check wiring and connections
    • Check / Replace Mass Air Flow (MAF) (G70)
    17963/P1555 - Boost Pressure Control: Upper Limit Exceeded
    Possible Symptoms
    • Reduced power output
    • Limp mode
    Possible Causes
    • Boost Pressure too High
    • Hoses/Pipes incorrect connected, disconnected, blocked or leaking
    • Charger Pressure Control defective
      • VNT (variable nozzle turbo): nozzles stuck
    • Solenoid Valve for Boost Pressure Control (N75) defective
    Possible Solutions
    • Check Hoses/Pipes to/between Components
    • Check Solenoid Valve for Boost Pressure Control (N75)
    • Check / Clean / Replace Charge Pressure Control
      • Check / Clean mechanism for variable nozzles
    00778 - Steering Angle Sensor (G85): Mechanical Failure
    Possible Causes
    • Steering Angle Sensor (G85) Basic Setting lost
    • Steering Angle Sensor (G85) Installation Position incorrect
    • Suspension Geometry incorrect
    Possible Solutions
    • Perform Steering Angle Sensor (G85) Basic Setting
    • Check Steering Angle Sensor (G85) Installation Position
    • Check Suspension Geometry
