cough every 2-3 seconds 2.0 tdi A3 2006
vw754 Apr 7, 2009
  1. vw754
    vw754 vorsprung Durch Technik
    2,336
    58
    my 2.0 tdi a3 when on idle seems to cough/hiccup ive cleaned egr and replace airfilter but cant seem to find what causing this,vag has been used and after a full scan no faults were found.
  2. kwempe
    kwempe New Member
    Mine does this too, I believe its quite common. I used injector cleaner and after driving for a few hundred miles it improved. I also Bluefinned my car and it hardley ever does it now. Maybe the mixture is run a little too lean for comfort?
  3. scobs
    scobs New Member
    having the same problem only when cold i just changed the adaption for idle control and got better i need to check it again in the morning,gonna check the timing ive checked everything else
