Cost to fit springs? Fronts only
A_man Jan 3, 2018
  1. A_man
    A_man New Member
    I’ve got some Eibach springs for my 2011 S3 sportback that need fitting. I’ve been quoted £216 to fit them by the independent Audi specialist I use in London. Sounds a bit steep to me just for the fronts, what do you think?
    Any advice much appreciated.
  2. jackal_s3
    jackal_s3 Member
    37
    12
    I had a full set of springs and shocks,front and back,fitted to my Mk1 Leon Cupra R few years ago for about £130.
    Different cars I know but similar suspension construction so I’d say that’s very steep just for front springs.
  3. -Ju-
    -Ju- Well-Known Member VCDS Map User Team Panther Audi S3
    2,495
    575
    For a competent garage with proper equipment, that's an hour's work at most. I've done it on my drive with axle stands in around that so I know it's a doddle of a job.
    There is also tracking to do and I assume that's included in that price?
    A proper 4 wheel hunter alignment is around £60
    I'd be paying no more than £120 with a proper alignment
  4. A_man
    A_man New Member
    Thanks for that guys, he didn’t mention tracking, I was however gonna get the hunter aligngnement done separately afterwards(I don’t think they have a hunter) as I’ve also just had tyres all round.
  5. strada
    strada New Member
    17
    I would charge £100+VAT for that.
    A_man likes this.
  6. maxpayne
    maxpayne Active Member
    431
    73
    What’s the Audi specialist and whereabouts?
  7. R222cet
    R222cet Member
    128
    20
    I’m booked in at awesome gti to have 4 shocks and 4 springs fitted plus wheel alignment £199
  8. audismart
    audismart YOU ARE JUDGED BY THE CAR YOU DRIVE.
    1,367
    297
    They are McPherson struts and easy to do, the book time is 2.5 hours for all 4 corners with alignment.
    An A4 on the other hand is multi link and a pita to fit. Phone them up again and with knowledge and see what they say.
  9. A_man
    A_man New Member
    Thanks for that had another quote for £120 from a reputable tuner which is a bit more like it. I’ve heard I should let it ‘settle’ before doing the alignment. Is this true or can it all be done together?
  10. -Ju-
    2,495
    575
    It may take a few months to settle so I'd be inclined to have it done at the same time as a temporary measure tbh.
    I think my H&R's dropped a further 5-10mm over 4 months so not night and day difference
  11. audismart
    1,367
    297
    When I fitted mine I had the alignment done and they let me bring it back free of charge after 1k miles for a check and adjustment if necessary.
    Good quality springs like Eibach or H&R are pre form heated and tempered so will barely differ from the day they are fitted and through there service life.
