Cost of replacing ARB
vishal Jul 27, 2006
  1. vishal
    vishal Member
    75
    My Anti- roll bar needs to be replaced, along with the bushs also, i find this a lil strange as my car has only covered 27k miles, its a 2001 S3.
    What kind of cost do you think i would be looking at to do this job?
    Ive had 2 S3's prior to this, and this same fault has occured on all 3 S3's ive owned! Time for Audi to reconise this as a fault i think!
    Anyway, have been quoted about 160 to have this done, and also been told that the car does not need 4 wheel alignment afterwards either by a specialist, do this sound right to you guys?
    Thanks for the advice
  2. leecs3
    leecs3 thinking about stuff
    604
    Its a 2hr job to replace the ARB's and you don't need to do a 4 wheel alignment unless they drop the wishbones too, which isn't the best idea in the world. Unless your charging by the hour. To change just the bushes, may not need to drop the subframe, you don't even need to remove the wheel on the drivers side.
  3. vishal
    vishal Member
    75
    Will going for an uprated ARB, make a huge difference to the handling? To be fair, its pretty spot on already
  4. DPM
    DPM Site Sponsor Site Sponsor
    5,023
    206
    I personally think it does improve it but if your happy with it at the moment then why change i suppose!
  5. bantam1
    bantam1 Member
    529
    Are you on standard suspension? If so you have got to be kidding.
    B.
  6. starski4578
    starski4578 Member
    150
    how do you no when your ARB needs replacing i sometines have a knocking noise over speed bumps but the garage have cast there eyes over it but cant tell me what it is. Sometimes its fine, its definately nothing to do with the suspension. Is it more likell to be a bush somewhere?
  7. leecs3
    604
    makes a massive difference if you go for the H&R's. Tranform the car, will not roll at all, great fun watching BM's almost tipping over trying to keep up lol.
  8. vishal
    vishal Member
    75
    yeah, im on standard suspension, so u guys think the uprated ARB will be noticeable?
  9. fingermouse
    fingermouse thats me
    4,003
    112
    ok the rear arb is a doddle 30 min job,
    the front is harder and you have to drop the subframe, not so for the bushes but then the bushes is only a 1hr job tops. 4 wheel alignment is recommended if you drop the subframe but if your carefull it should go back where it was.
    ive done both now to R32 arb the rear was the most noticable, the front has made the car better at speed.
  10. nwhiteley
    nwhiteley Member
    198
    how much do you have to drop the subframe???
    is it just a matter of undoing the 4 main bolts and allowing the S.F. to drop an inch or two....
    or does it have to be removed completely?
  11. nwhiteley
    nwhiteley Member
    198
    hi. could you please quote me on a Forge FMIC and the H&R ARB's, for my 2001 210 bhp S3
  12. nwhiteley
    nwhiteley Member
    198
    thanks Damian.
    i will have to leave the FMIC for now, its a bit too rich fro me at the moment.
    I will probably have the ARB's off you. Does the quote inc P&P & VAT.
    How would you want paying?
  13. nwhiteley
    nwhiteley Member
    198
    ... and is it possible to ship to my company address, but pay with my private CC?
  14. DPM
    5,023
    206
    Yeah the FMIC aren't cheap! Not a problem mate, all the details are in a PM that i've just sent you! :beerchug:
  15. leecs3
    604
    remove the rear bolts, loosen but don't remove the front bolts. Remove at the steering rack bolts. You lift the rack and pull the ARB out underneath it.
  16. fingermouse
    4,003
    112
    also the passenger side arb bracket also holds a pipe, this is a 10mm nut irc, cab be a swine to get to.
    the front dog mount bush/arm has to be removed this is easy.
