Correct codes for RNSE with factory bluetooth phone
kolash Jun 12, 2012
  1. kolash
    kolash Member
    46
    Hi
    We have retrofitted an RNS-E to my 2008 A3 sportback. The unit states that "telephone is not installed". I have factory bluetooth with GSM prep in the arm rest.
    In VCDS there are a number of code options:
    § 0xxx?xx: Telephone/Telematic
    § 1 = Telephone not installed (Remote Feed Voltage for Microphone active)
    § 2 = Base Plate (Temic - Remote Feed Voltage for Microphone inactive)
    § 3 = Base Plate (Cullmann - Remote Feed Voltage for Microphone inactive)
    § 4 = Base Plate (Nokia - Remote Feed Voltage for Microphone inactive)
    § 5 = Telematic Europa (Remote Feed Voltage for Microphone inactive)
    § 6 = Telematic US (Remote Feed Voltage for Microphone inactive)
    § 7 = Base Plate diagnostic capable with Comfort Control
    Which is the correct one for the bluetooth I have?
    Hope someone can help!
  2. s8craig
    1,747
    53
    In the voice of Len Goodman "Severn"
    But you should also recode your phone module to 0011422
  3. kolash
    kolash Member
    46
    Many thanks, after 1, 7 is one I thought least likely to be correct!!
    Yes had guessed the phone needed recoding too, and had noted that exact code.
    Will hopefully try it out tonight.
  4. kolash
    kolash Member
    46
    All works perfectly now, thanks mate!
