Cornering Fog Lights
8ig_steve Nov 12, 2010
  1. 8ig_steve
    8ig_steve Member
    39
    Quite a few cars (e.g. latest Golf) now have one fog light come on (at night & at low speeds only) when you indicate, to improve visibility into dark turnings.
    I quite like this idea and was wondering if it can be done on the A3.
  2. PH1L
    PH1L Gievf Buckets
    3,851
    40
    i just noticed my mums merc estate doint this 2 nights ago didnt know it was a feature ive not seen any coding for it via vagcom, try asking around the golf forums if one of them has gotten it to work it can be transplanted to teh a3
  3. slade777
    slade777 Member
    763
    Ive seen this as well on a few cars both my mates clio and punto evo have it. Personally i havent seen a need for it especially with Xenons and even in both their cars it doesnt make a huge amount of difference. Just looks like theyve got a fog light out when turning.
  4. Khufu
    Khufu Well-Known Member
    5,704
    31
    It might be possible only on newer modules - ie MY10 onward. They have completely changed the CE module so they may have introduced it with that.
  5. TFSI
    TFSI Born to Fish
    540
    52
    MAN Trucks TG-S and TG-X have been doing this for the last 4 years ! But seeing as they fit the same FFR (Vehicle Management Computer) as the VAG range its not surprising.
    MAN Trucks engineered and styled by Audi. Look at the grill on the next newish MAN you see and if you can have a butchers at the dash arrangement and you will see exactly what i mean.
    So guys your pride and joy got its electronic platform from a dirty big TRUCK, waddya think of that ????
  6. s3reptdi
    s3reptdi Member
    179
    Can this be done in VCDS for a 2005? Ive had a look but cant see it?
  7. Wicked666
    Wicked666 Active Member
    584
    35
    I don't like this feature as looks as though a car has a bulb out.
  8. s3reptdi
    s3reptdi Member
    179
    It makes it better to see the road, not bothered what it looks like
  9. coreythorny
    coreythorny Active Member
    452
    73
    Leon Cupras do it IIRC, at least I've seen one do it!
    i can only think its a kind of AFL type of function, I admit would be happy. Maybe some of the coding wizards can advise. I the meantime i might look into what Seat call it.
  10. coreythorny
    452
    73
    Didn't take long:
    would appear not to be the normal fog but a split lense with another light for this function.
  11. a6_chris
    a6_chris Well-Known Member
    1,883
    159
    My 2009 has the option in vcds but doesn't work when enabled.
  12. Mikemc
    Mikemc Scooby Slayer VCDS Map User
    1,024
    37
    My 55 has the option but also doesn't work
  13. t8ups
    t8ups Site Sponsor Site Sponsor VCDS Map User
    1,977
    692
    I activated them for a customer when he had all his bulbs upgraded, that was a 62 reg so 8p3 cars will have the option.
    Trups
  14. BenC00
    BenC00 Member
    97
    I enabled this on my 2009 8P3 with VCDS: You need to enable 2 things in Central Electronics Module:
    'Corning lights via fog lamps' and 'Internal turn light algorithm'
    I found this image on the web to help you but your VCDS screen will probably look different.
  15. danb986
    danb986 In awe of VCDS Team Daytona
    518
    58
    It's even easier on my 2010. (probably the only thing that is actually easy on a 2010)
    I just ticked the button that said Cornering lights via fog lamps and they worked.
    I just need some whiter bulbs now, the fogs look almost brown compared to my xenons and drl's
