cools down when drive heats up on idle?
neil278 May 1, 2012
  1. neil278
    neil278 New Member
    recently had to change the gasket and temp sender housing but since ive done this when the cars driven it cools right down but when ideling it warms up anyone any ideas?
    I've only had the car a few weeks so not to sure if its done it before or not
    Cars an A3 8L 1.8 non turbo
    Thanks in advanced
  2. Prawn
    11,455
    3,352
    thermostat stuck open for sure. it heats up in idle as there is no airflow over the rad, when driving the rad overcools and it drops to 60ish.
    Can be bought about by dropping the coolant and refilling, as you can dislodge **** in the system, or maybe just bad luck.
    Either way, a new stat is about £12, and about 30 mins to fit.
  3. s3 Hoggy
    s3 Hoggy Whats going on???
    1,716
    158
    Thermostat by the sounds of it mate
  4. neil278
    neil278 New Member
    o joy! I droped the coolent only to find audi gave me the wrong oring then again to change that only to find i had some how cracked the housing for the temp sensor
    not having much luck at the moment but looking on the bright side i know the cooling system inside out!
  5. neil278
    neil278 New Member
    forgot to say cheers for the replys guys!
  6. AudiiduA
    AudiiduA Member
    359
    Deffo stat mate easy fix
