Cooler air at idle
vwgtiking Nov 21, 2013
  1. vwgtiking
    vwgtiking Active Member
    1,027
    When I have the heaters on hi and engine warmed to 90 they blow really hot air which is fine, but soon as I stop in traffic or at lights the heater blows cool air or barely warm. What's causing this?
  2. stu_m
    stu_m Well-Known Member VCDS Map User
    1,440
    its probably the cold winter air causing it!!
    I'm guessing its a TDI? they run cooler and cool down quicker
  3. S4_dan
    S4_dan Fire up the Quattro! VCDS Map User
    2,699
    157
    Weak thermostat, air in the system, weak water pump, or just generally cold outside.....
    Try placing a piece of cardboard in front of the radiator and see if that makes any difference.....BUT KEEP AN EYE ON YOUR TEMP GAUGE IF YOU DO THIS.
  4. vwgtiking
    1,027
    It's a 1.8t. Why would cold affect it? Engine hot then hot air? Never had issue with mk4 golf 1.8t.
    How easy is it to change thermostat on these b6s?
  5. vwgtiking
    1,027
    Water pump done recently.
