coolant warning
964russ Jan 24, 2014
  1. 964russ
    964russ New Member
    20
    So I fitted new brakes today (discs & pads) so the brake warning light has gone off.
    And guess wot, another has appeared same day!
    Coolant warning light.
    Coolant is full, no issues with over heat.
    So I presume its the bottle sensor.
    Can I buy the sensor or is it a new bottle?
    Part nos pls?
    Thanks.
  2. TYphoon GB
    TYphoon GB Active Member
    386
    26
    The pins on the wear indicator are pathetic...and the clip that holds the two parts together ain't much better.
    I wrapped a slip of tin foil in to each of the female stakes on mine as it went off with every puddle.
    Then a wrap of tape to ensure both halves of the connector are tight up.
    Gentle scrape of the metal pins inside the Coolant reservoir with a screw driver usually helps.
    If not pull it out and soak in scale remover for 5 mins (no more)
    Otherwise...6 cylinders should be 8E0121403D
