coolant warning light DIS 2.0 TDI (2005)
john_cook Dec 14, 2007
  1. john_cook
    john_cook I was the STIG.
    216
    Hi everyone,
    can anyone tell me what coolant I need to buy to fill up the reservoir? The light came on about a week ago and is on everytime I start the car. On inspection in the engone bay it is near the minimum level. Do i simply buy some replacement coolant solution and top it up? It had its 2nd service in September and had no such problems then.
    Cooky
  2. Amchlolor
    Amchlolor Active Member
    5,604
    You MAY have the porous cylinder head problem that a few 2.0tdi owners have reported. (check this forum for previous threads about coolant loss).
  3. dipstic
    dipstic Member
    384
    Wait untill the engine is cold,undo cap,top up with water(any water will do just for top up) to the max mark and keep an eye on it and see if the light comes back on.If so get it checked out.
  4. john_cook
    216
    Is that safe?? Maybe I should take it in to audi or call them.
    Cooky
  5. s3mike
    s3mike Member
    240
    I noticed the other day when topping up washer fluid that my coolant is quite low.
    Car was very cold but the level was around minimum. The warning light hasn't come on and I realise the level goes up when the car is warm but I'm not sure it should be so low.
    Hope I don't have a leak!
    I did spend a couple of hours last weekend at Rally GB with the car idling, maybe this has used some coolant?
  6. dipstic
    dipstic Member
    384
    From the manual
    When cold level should be between min and max level
    When hot might be slightly above max mark
    System should not loose coolant if it is visit to Dealers req
    So I would suggest topping it up when cold and seeing if it then loses fluid, if it does take it to the dealer to check
  7. s3mike
    s3mike Member
    240
    Thanks, I'll take a look today. Normally when hot it was abit above maximum, not sure if it's dropped or just because the car was cold ( and outside temp was near freezing too ).
    I've had it for 3 months so hopefully there is no leak!
  8. Davidb67
    Davidb67 Member
    152
    I had the dreaded "porous cylinder head" problem on my `54 2.0TDi at around 83k miles/38 months.....
  9. kanievsky
    kanievsky Member
    How much did it cost you to have it fixed? Have you had the head replaced?
  10. alnes
    alnes Member
    45
    hi guys i had the head replaced at 60k audi did it under warranty with just a small contribution from my self, total cost was just under £2200 & you get 2years warranty, done approx 1k miles since all fine.
