Coolant warning alarm
gash Apr 29, 2012
  1. gash
    gash Member
    34
    I started a thread a couple of days ago saying I had a oil pressure warning come on. Turns out that it was actually a coolant warning.
    To be honest it is a bit if a relief because I was worried I may have done some damage to the engine if it was ran dry.
    Brings me to the next question of why the alarm came on, it was only on for about 20 secs then went off again, not seen it since. Any one got any ideas why this warning came on for such a short period of time?
    Temp gauge is bang on 90.
    I was sitting on a slight hill at the time, could this have caused it?
  2. <tuffty/>
    21,874
    4,201
    Check the level of coolant in the expansion bottle...
  3. gash
    gash Member
    34
    Cheers tuffy al have a look tomorrow.
    Any idea why it would come on for a short period then back off again?
  4. <tuffty/>
    21,874
    4,201
    Generally they beep to grab your attention then stay on the dash for a bit... could be that getting onto a flat bit of road was enough to wet the sensor electrodes enough to clear it...
    Gauge being bang on 90 means little tbh... the gauge hits 90 then stays there until something like 100/105 degrees (can't remember the exact number) then throws a warning on the dash and then I think the gauge increase in temp..
    I suspect you r issue is more likely low coolant though...
  5. gash
    gash Member
    34
    Cheers again tuffy, as I said I will check tomorrow and post tge out come.
  6. Gops
    3,198
    666
    Wasnt there an issue with the coolant bottle level sensor? I had it pop up but coolant level was fine. Put about 100ml in and it went! Comes up on cold days usually.
  7. vfr800
    vfr800 Active Member Team Dolphin Grey Audi S3 quattro Audi A6
    775
    57
    If the coolant level is fine it will be the coolant level sender. (in my experience - it's worse when it's cold)
    Open the cap on the coolant expansion tank, when you look inside there are two metal probes.
    Over time these built up crud/limescale which prevents the sensors from sensing the correct level.
    There are two ways to fix.
    1) Buy a new expansion tank. £15? ish.
    2) Carefully clean the probes.
    I opted for option 2 on my A3 because if I screwed it up a new tank wasn't much and I was about to sell the car anyway.
    I removed the header tank and rinsed it out, I used a long flat-bladed screw driver to carefully scraped down the length of the wires. You can feel when you're removing limescale or down to bare metal. Do your best to clean them off all around. Rinse it out again and refit.
    Liam
