Coolant Temperature sensor location in the 1.9TDi AJM
B5NUT Jun 20, 2011
  1. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group S-line owners group
    3,757
    659
    Drove to work and got no temp on the dis, so if figure the sensor is gone. Went to ECP to get a new one however there are two options listed for my engine “Green” & “Blue” they could not tell me the difference, and I’ve got no idea what is fitted to my car or the location, anyone know the location of this or which one would be fitted to my car.
    The car is a 2000 MY with the 1.9 AJM engine 115 BHP
  2. adamss24
    adamss24 Well-Known Member
    4,584
    406
    It's on the back of the engine in the black plastic flange with the hoses for the heater matrix (follow the 2 hoses next to the battery). Quite fiddly to get at- make shure the engine is cold to avoid scalding or to burn your hand on the catalist. Get a new clip - if plastic and a new o-ring !
  3. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya TDi saloon
    15,161
    1,122
    I got a spare sender at home that I don't need.
    I'm happy to sell it on to you if you want.
    Its complete with clip and O-ring.
    You can check the temp sender via the AC controls.
  4. B5NUT
    3,757
    659
    Thanks for the offer but I really wanted to pick one up today, ECP have both in stock I just don't know which one I have in the car.
  5. aragorn
    18,382
    831
    look at the plug.
    early type is square and late type is D shaped. I suspect you'll have a d-shaped one given the age (which is probably green)
    Color alone might not be enough.
  6. B5NUT
    3,757
    659
    Correct, found the colour went back and was given another 2 option of plugs, went fot the D type.
  7. Jason.s
    Jason.s Active Member
    2,879
    348
    4 pin green is pretty much fitted to almost everything from 99 onwards across the VAG range. Sell them like they`re going out of fashion at work lol
