Coolant Temperature Guage
filipharvey May 22, 2008
  1. filipharvey
    filipharvey Amusing Tagline
    519
    I posted this in the A6 lounge, but as a lot of you A4 owners have the 1.8T engine, I guess it would be applicable in here too.
    Basically my guage is reading high at speed and normal at lower speeds.
    Any ideas?
  2. olds_kool
    olds_kool Active Member VCDS Map User
    1,089
    13
    is it moving smoothly or eratically, eratically would suggest temp sender, by normal do you mean needle is pointing straight up 90 deg c ish
  3. filipharvey
    519
    Yeh, normal being 90. It then goes up to 110 within about 10 seconds and doesn't generally (although I've only driven about 60 miles) go back down to 90 until I slow down.
  4. AndyMac
    9,832
    45
    Usually a knackered temp sender will under read or fail to read anything at all and often cause erratic idle & stalling. Sounds more like thermostat is stuck closed, but try the temp sender first as it's only £20 and a 30minute DIY job
  5. olds_kool
    1,089
    13
    id go with the thermostat first then, i had opposite problem with old car wouldnt reach normal temp so thermostat stuck open? only cost £7 for thermostat but £20 for correct red coolant.
    fairly easy diy expect wet arm though and note which way round it goes, did mine on my new car when i bought it as i was flushing coolant anyway and it seems a common failure part so didnt want it to fail a few months after flushing system
    i replaced sender first and made no difference so put old one back and added new one to my spare part collection, sender is at rear of engine 9opposite side to belts) if you want to change it.
    andymac how did it take you 30 mins? 3 coffee breaks?
  6. low610
    low610 Member
    125
    I'd go for the temp sensor, about £20 from Audi and as said, you can fit this yourself.
    Just make sure the engine has cooled down, i made this mistake when changing mine. :)
  7. AwesomeSarah
    AwesomeSarah Member
    726
    Maybe even worth thinking about water pump
    Part of the water pump breaks off
    At normal steady speeds it is OK
    Motorway driving the rest of the impella cannot keep up
    So temp goes up
    Has it been replaced before?
    Sorry
    Sarah
  8. Markey
    Markey Active Member
    2,175
    Sounds like an idea.
  9. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,769
    31
    I 2nd that Sarah, defo sounds like water pump to me.
  10. olds_kool
    1,089
    13
    makes sense!. you can get ones with metal impellars to prevent it happening again
  11. Markey
    2,175
    When i replaced my plastic one it had bits missing all over.
  12. AwesomeSarah
    AwesomeSarah Member
    726
    Sorry , it is more expensive than temp sensor too :(
    Sarah
  13. AndyMac
    9,832
    45
    Slightly, £20 vs £400 (as you'll need to do cambelt/tensioners etc at the same time)
