coolant temp sensor
dantheman1986 Feb 11, 2007
  1. dantheman1986
    dantheman1986 Member
    262
    can anyone tell me where this is located on the engine? ive heard there is a grren on and a blue one? does it matter which one i get? i have a a3 1.8 tqs
  2. S3 AJU
    S3 AJU New Member
    17
    I changed the coolant temp sensor on my S3, im not too sure about the set-up on the A3 1.8 T.
    Check out the link below this was for a TT
    http://www.wak-tt.com/tempsensor/tempsensor.htm
    If it is the same then, it's a 5 min job, be careful make sure the engine is cold and release the lid on the water coolant. I lost alot on my coolant and had to replace the coolant which is not a bad thing.
  3. shollis
    shollis flat in fifth.....
    I will second that, make sure it is cold!!!
    Took 2 minutes once I worked out where the sensor was on my 1.8 T Sport.
  4. dantheman1986
    262
    how many differnt versions of thissenderis there? anyon got a pat numbe rfor the one i need?
  5. Stewart
    Stewart Member
    705
    10
    Congratulations! You get the award for the most un-intelligible sentence this month :)
  6. s3tle
    s3tle Member
    239
    it will either be oval like the one in Waks write up or square, just locate and unplug the wire to see what shape the socket is, most are oval.
  7. S3tony
    S3tony Member
    395
    when i changed mine they went on how many wires came out of the conector
  8. dantheman1986
    262
    lol thanks for that, my key board is a bit sh**ged as you can tell lol
