Coolant temp sensor help please.
daz-20vt Dec 25, 2013
  1. daz-20vt
    daz-20vt Well-Known Member
    2,835
    582
    Hi guys. Merry christmas to start hope everyone is well. Just wondering. I have a faulty coolant temp sensor. Is this an easy diy or shall i book the car in. will i lose coolant doing it. Any info would be great. Thanks. Daz
  2. Bad Sir Culation
    Bad Sir Culation Member
    287
    17
    You'll only lose a bottle cap full of coolant. It's probably the easiest job on the car. You pull out the plastic clip on the sensor, it comes out. That's it. Stick the new one in and replace the clip.
  3. CazzaVR
    CazzaVR Member
    259
    14
    As above - easy peasy :)
  4. Wallm0nkey
    Wallm0nkey Member
    225
    You lose a cup at most is a nice easy swap!
  5. epox
    epox Active Member
    772
    74
    As above easy
  6. daz-20vt
    2,835
    582
    Lovely guys thanks. Ill get right on it!!!
  7. epox
    epox Active Member
    772
    74
    PS get an OE sensor, bit costly I know but I have had 3 eBay ones fail within 9 months.
  8. m19lte
    m19lte Member
    123
    PS2 undo the filler cap 1st, and or when the engine is cold !
  9. Drewvic
    Drewvic Member
    204
    may sound abit dumb but does anyone have pic of location of sensor and thermostat please I think my need changing thanks peeps
  10. Wallm0nkey
    Wallm0nkey Member
    225
    Here's a little guide but it's easy enough to find if you know the general area! VWVortex.com - DIY: Replacing your temperature sender with the updated one (green-top)
    Thermostat is hard to get a nice pic of but if you get that little cover off by the dipstick then the metal bracket and pull the dipstick out. It's to the left behind the alternator it's a hard black pipe with two little bolts and a radiator pipe running off the housing. I couldn't really see from the pics but have a little poke about and it becomes clear!
  11. epox
    epox Active Member
    772
    74
