Yikes quite a lot going on there.
Are they all fresh? IE if you clear them, do they all come back?
I suspect its something similar to the problem on here the other day after the boy had fitted a stereo. Turned out the wiring to one of the sensors had chafed thru, grounding out that "branch" of the wiring loom.
Also, Free Vagcom is a bit strange with 1.8T's, Those figures you've quoted arent coolant temp readings. flick thru the ones around there and look for degrees C in the units. IIRC the one you want will display two, the coolant temp on panel 3 and intake temp on panel 4, but they're mislabelled.
