Coolant temp reading low
mattoo Aug 22, 2009
  1. mattoo
    mattoo New Member
    14
    Hi folks, so I've only owned my A3 quattro for a couple of months and I love it!
    But there is now a strange problem with the coolant temp gauge..
    It used to be that the needle sat right in the middle of the gauge when warmed up, but now it barely makes it over the second notch (70degs).
    Once the car is up to temp and I leave it for a few minutes when I turn the key the temp gauge goes to the middle 90 degs.
    Then when while driving down goes the temperature gauge..
    The interweb suggests it's the sender but what do you all think?
  2. A3Tom
    A3Tom Smell my finger.
    3,504
    14
    Sender mate, had it on mine.
    Cost is about 12 quid from GSF and will take about 10 minutes to fit...easy peasy
    T
  3. Jacko4130
    Jacko4130 Goodie Gum Drops
    848
    Sender or thermostat
    When i did mine it was the thermostat
  4. <tuffty/>
    21,688
    4,119
    This problem is common as muck on 1.8t's, had the same on my S3. Mine was the thermostat but I replaced the sender too. Stat is more of a pain to replace but as Tom said, the sender is a piece of cake and worth changing anyway.
  5. markyR
    markyR Member
    118
    sounds like thermostat to me aswell, replaced 2 of these as causing the same problem on both of my a3's i've owned. if you require a temp sensor i would go genuine as i've heard that non gen ones dont last long.
    cheers mark
  6. mattoo
    mattoo New Member
    14
    Sorry for dragging up an old thread but I've had a good result. Weeks ago I changed the coolant sender, but was still not right..
    Today the thermostat was done and all is well!
    Thank you all ..
  7. ianysm
    ianysm Active Member
    1,002
    Any other symptoms of this? lumpy idle etc? thought i'd read they are connected
  8. steviet
    steviet Member
    439
    Ive got a brand new temp coolant sensor if you want one?..:salute:
