Coolant System Pressure Testing
Discussion in 'Awesome GTI' started by Pabs, Nov 9, 2010.
  1. Pabs
    Pabs Active Member
    Hi Mike, do you do coolant system pressure testing?? I have an Audi A4 B6 1.8T 190 S-Line, and it has started loosing a bit of coolant??
    Cheers Paul
  2. CHRIS555
    CHRIS555 DOPE with added OCD
    If nothing noticeable it's worth considering it could be your water-pump - mine was leaking but I could never find a leak as such anywhere, but when my cambelt and water pump was changed - problem solved!
  3. CHRIS555
    PS. Sorry Mike for hijacking the post ;) Pass my regards onto Sarah
  4. Pabs
    Pabs Active Member
    I thought it could be the water pump but i had it changed with the cambelt just over 2 years ago, its just out of audi warranty I'll get it checked and see, if its the water pump audi can fix it the car has only done 10,000 miles since it was changed. Thanks for the advice.
  5. AwesomeMike
    AwesomeMike Member
    Sorry about the delay - for some reason the motortrade is usally quiet in Nov and Dec but its just totally manic at the moment!!! Not getting a monent to myself!! :p
    As Chris mentioned:
    If you are still not having any luck give me a shout and we will see what we can do for you :D
    Mike
